Re: Odd BuildViewer.xml build failure [message #229707 is a reply to message #229690] |
Thu, 22 March 2007 23:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
David J. Orme wrote:
> I've been following the build instructions on 262 of "Integrating and
> Extending...", but trying to apply them to branch 2_1_3. I get to the
> last step on page 263 and get the following error from Ant.
> [native2ascii] Converting 3 files from
> C:\Cygwin\home\djo\workspaces\birt\org.eclipse.birt.data.oda \src\org\eclipse\birt\data\oda\util
> to
> BUILD FAILED
> C:\Cygwin\home\djo\workspaces\birt\org.eclipse.birt.report.v iewer\BuildViewer.xml:217:
> The following error occurred while executing this line:
> C:\Cygwin\home\djo\workspaces\birt\org.eclipse.birt.report.m odel\BuildModel.xml:381:
> C:\Cygwin\home\djo\workspaces\birt\org.eclipse.birt.data.oda \BuildOda.xml:235:
> Error starting Sun's native2ascii:
> Apologies if this is a newbie question. Searching Eclipse.org for
> native2ascii yields 0 hits. Thanks in advance for your assistance.
> Dave Orme
Does the native2ascii command run from a command prompt?
What version of Java are you using?
Jason
Re: Odd BuildViewer.xml build failure [message #229861 is a reply to message #229848] |
Fri, 23 March 2007 14:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I built the 2.1.3 branch last night. I set the java compiler settings
to 1.4 and had to add org.eclipse.birt.report.model.util to the exported
packages in the org.eclipse.birt.report.model plugin. After making
that change and adding the two external itext jars my build worked. I
also built the viewer running BuildViewer.xml. I am using Java 5.
I wonder if this is the issue. I assume you have eclipse.home set.
The line it is failing on in your build is
<native2ascii encoding="GBK"
src="${src}/org/eclipse/birt/data/oda/util"
dest="${src}/org/eclipse/birt/data/oda/util"
ext=".java"
includes="OdaResources_zh_CN.msg"
Does the zh_CN.msg file exist in your org.eclipse.birt.data.oda plugin?
Jason
>>> the last step on page 263 and get the following error from Ant.
>>> to
>>> BUILD FAILED
>>> Dave Orme
> Yes.
> Java 6.
> Dave
Re: Odd BuildViewer.xml build failure [message #229946 is a reply to message #229938] |
Fri, 23 March 2007 18:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Glad to hear Dave.
>> exported packages in the org.eclipse.birt.report.model plugin. After
>> making
>> ext=".java"
>> Jason
>>>>> and Extending...", but trying to apply them to branch 2_1_3. I get
>>>>> to the last step on page 263 and get the following error from Ant.
>>>>> to
>>>>> BUILD FAILED
>>>>> Dave Orme
>>> Yes.
>>> Java 6.
> My bad. I had a JRE selected to compile against, not an SDK, so the
> path wasn't being set correctly before ANT was invoked.
> Thanks again, Jason.
> Dave Orme
Re: Odd BuildViewer.xml build failure [message #229954 is a reply to message #229946] |
Fri, 23 March 2007 19:14 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Dave Orme![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=djo%40coconut-palm-software.com) Messages: 424 Registered: July 2009 |
I got everything built. FYI: I had to import org.apache.batik,
org.apache.batik.pdf, and org.apache.xerces plugins into my workspace in
order for everything to build.
Does this sound right or should I file a bug?
Dave Orme
> Glad to hear Dave.
>>> settings to 1.4 and had to add org.eclipse.birt.report.model.util to
>>> the exported packages in the org.eclipse.birt.report.model plugin.
>>> After making
>>> I also built the viewer running BuildViewer.xml. I am using Java 5.
>>> ext=".java"
>>> /> Does the zh_CN.msg file exist in your
>>> Jason
>>>>>> get to the last step on page 263 and get the following error from
>>>>>> Ant.
>>>>>> to
>>>>>> BUILD FAILED
>>>>>> Dave Orme
>>>> Yes.
>>>> Java 6.
>> Regards,
>> Dave Orme
Senior Consultant, Trainer
Coconut Palm Software, Inc.
http://www.coconut-palm-software.com
Re: Odd BuildViewer.xml build failure [message #230236 is a reply to message #229954] |
Mon, 26 March 2007 03:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Dave,
What BIRT package did you have installed when you started building the
source? The allinone or the framework or neither? I may need to update
the build docs to reflect this requirement. I used the allinone, and
the batik files existed in my environment.
Jason
> Dave Orme
>> Glad to hear Dave.
>>>> After making
>>>> ext=".java"
>>>> Jason
>>>>>>> Ant.
>>>>>>> to
>>>>>>> BUILD FAILED
>>>>>>> for native2ascii yields 0 hits. Thanks in advance for your
>>>>>>> assistance.
>>>>>>> Dave Orme
>>>>> Yes.
>>>>> Java 6.
>>> Regards,
>>> Dave Orme
FUDForum. Page generated in 0.03897 seconds
