Installation for JAVA programing [message #22396] |
Tue, 01 February 2005 16:05 |
Originally posted by: PoMec.PoMec.Net
Everyone,
I am new to eclipse and am trying to put it on a Fedora Core 3 system. I
would like to use it as I learn how to program in JAVA. I have it (3.01)
installed, but have no references to JAVA when I use it. According to the
literature I should be able to have an entry for JAVA when I try to create
a new Project, but JAVA is not listed. CVS and Simple are listed but not
JAVA.
I downloaded and installed:
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_01-b08)
Java HotSpot(TM) Client VM (build 1.5.0_01-b08, mixed mode, sharing)
It seems to be running, but I am only begining to have experience with it
so I would not be surprised if I have made mistakes.
Sure would appreciate some help.
Greg Ennis
Re: Installation for JAVA programing [message #22574 is a reply to message #22396] |
Tue, 01 February 2005 16:42 |
Darin Swanson Messages: 2386 Registered: July 2009 |
Greg,
It would appear that you downloaded a version of Eclipse that does not
include the Java support.
You need to download the full Eclipse SDK (about 90 MB)
HTH
Darins
"Greg Ennis" <PoMec@PoMec.Net> wrote in message
news:cto9c0$el8$1@www.eclipse.org...
> Everyone,
> JAVA.
> Greg Ennis
Re: Installation for JAVA programing [message #22791 is a reply to message #22574] |
Tue, 01 February 2005 19:57 |
Darin,
Thanks... I downloaded the gtk version should I have used the motif
version?
Greg
Darin Swanson wrote:
> Greg,
FUDForum. Page generated in 0.07776 seconds
