Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Plugin dependencies and cspex file
Re: [buckminster-dev] Plugin dependencies and cspex file [message #22380] |
Mon, 21 July 2008 11:19  |
Originally posted by: jcampolongo.cra.com
------_=_NextPart_001_01C8EB45.21D6B0BD
Content-Type: text/plain;
charset="US-ASCII"
Just to re-iterate, the 'View CSpec' action give me a cspec file that
has the following block in it:
=20
<cs:dependencies>
<cs:dependency name=3D"OSGi_Dependency"
componentType=3D"osgi.bundle" versionDesignator=3D"1.0.0"
versionType=3D"OSGi"/>
</cs:dependencies>
=20
Then, running the project with debug turned on, I don't see anything
having to do with dependencies at all. It is all very strange. Note
also that if I keep the buckminster.cspex file and add the dependency to
the manifest.mf, I still don't get the dependency being built. Only if
I have the dependency in the manifest file and the buckminster.cspex
file doesn't exist does it get built.
=20
I'm guessing that I'm doing something wrong somewhere, but it is opaque
enough to stymie me.
=20
Actions to perform (in order)
com.cra.project:osgi.bundle$1.0.1#OSGi#target.fragments
com.cra.project:osgi.bundle$1.0.1#OSGi#eclipse.build
com.cra.project:osgi.bundle$1.0.1#OSGi#bundle.jar
[start com.cra.project:osgi.bundle$1.0.1#OSGi#eclipse.build]
target.arch=3Dx86
PROJECT_Runtime=3Dc:\Project_metronome
buckminster.component=3Dcom.cra.project
workspace.root=3DC:/Documents and Settings/jcampolongo/workspace
=20
buckminster.temp=3DC:/DOCUME~1/JCAMPO~1/LOCALS~1/Temp/buckmi nster/com.cra=
=2E
project_1.0.1-osgi.bundle/temp
buckminster.home=3DC:\dev\Project\trunk\Metronome-Project\
=20
buckminster.output=3DC:/DOCUME~1/JCAMPO~1/LOCALS~1/Temp/buck minster/com.c=
r
a.project_1.0.1-osgi.bundle/build
localhost=3Djcampolongo-dt1
buckminster.component.type=3Dosgi.bundle
buckminster.version.type=3DOSGi
buckminster.version=3D1.0.1
target.nl=3Den_US
target.ws=3Dwin32
eclipse.home=3DC:\eclipse
target.os=3Dwin32
target.location=3DC:\dev\Project\trunk\target_platform
[end com.cra.project:osgi.bundle$1.0.1#OSGi#eclipse.build]
Action com.cra.project:osgi.bundle$1.0.1#OSGi#bundle.jar using 'up to
date' policy COUNT: Rebuild needed: File count(0) < expected(1)
[start com.cra.project:osgi.bundle$1.0.1#OSGi#bundle.jar]
Product alias =3D action.output
Product base =3D ${buckminster.output}\jar\
target.arch=3Dx86
=20
=2E
=20
r
target.nl=3Den_US
target.ws=3Dwin32
target.os=3Dwin32
[end com.cra.project:osgi.bundle$1.0.1#OSGi#bundle.jar]
=20
Joseph Campolongo
Charles River Analytics, Inc.
=20
=20
=20
=20
THIS MESSAGE IS INTENDED FOR THE USE OF THE PERSON TO WHOM IT IS =
ADDRESSED. IT MAY CONTAIN INFORMATION THAT IS PRIVILEGED, CONFIDENTIAL =
AND EXEMPT FROM DISCLOSURE UNDER APPLICABLE LAW. If you are not the =
intended recipient, your use of this message for any purpose is strictly =
prohibited. If you have received this communication in error, please =
delete the message and notify the sender so that we may correct our =
records.
Content-Type: text/html;
charset="US-ASCII"
<HTML >
<HEAD>
<META http-equiv=3D"Content-Type" content=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DGenerator content=3D"Microsoft Word 11 (filtered medium)">
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{margin:0in;
margin-bottom:.0001pt;
font-size:12.0pt;
font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
font-family:Arial;
color:windowtext;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;}
div.Section1
{page:Section1;}
</style>
</HEAD>
<BODY lang=3DEN-US link=3Dblue vlink=3Dpurple>
<DIV>
<DIV>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Just to re-iterate, the ‘View CSpec’ =
action give
me a cspec file that has the following block in =
it:<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p >
font-family:Arial'> =
<cs:dependencies><o:p></o:p></span></font> </p>
<cs:dependency
name=3D"OSGi_Dependency" =
versionDesignator=3D"1.0.0" =
versionType=3D"OSGi"/><o:p></o:p> </span></font></p>
</cs:dependencies><o:p></o:p></span></font ></p>
font-family:Arial'>Then, running the project with debug turned on, I =
don’t
see anything having to do with dependencies at all. It is all very
strange. Note also that if I keep the buckminster.cspex file and =
add the
dependency to the manifest.mf, I still don’t get the dependency =
being
built. Only if I have the dependency in the manifest file and the =
buckminster.cspex
file doesn’t exist does it get built.<o:p></o:p></span></font></p>
font-family:Arial'>I’m guessing that I’m doing something =
wrong
somewhere, but it is opaque enough to stymie =
me.<o:p></o:p></span></font></p>
<p class=3DMsoNormal style=3D'text-autospace:none'><font size=3D2 =
color=3Dblack
face=3D"Courier New"><span =
style=3D'font-size:10.0pt;font-family:"Courier New";
color:black'>Actions to perform (in order)</span></font><font size=3D2
style=3D'font-size:10.0pt;font-family:"Courier =
New"'><o:p></o:p></span></font></p>
color=3Dblack
color:black'> =
com.cra.project:osgi.bundle$1.0.1#OSGi#target.fragments</span ></font><fon=
t
size=3D2 face=3D"Courier New"><span =
color=3Dblack
color:black'> =
com.cra.project:osgi.bundle$1.0.1#OSGi#eclipse.build</span> </font><font
color=3Dblack
color:black'> =
com.cra.project:osgi.bundle$1.0.1#OSGi#bundle.jar</span></font ><font
color=3Dblack
color:black'>[start =
com.cra.project:osgi.bundle$1.0.1#OSGi#eclipse.build]</span ></font><font
color=3Dblack
color:black'> target.arch=3Dx86</span></font><font size=3D2 =
color=3Dblack
color:black'> =
PROJECT_Runtime=3Dc:\Project_metronome</span></font><font
color=3Dblack
color:black'> =
buckminster.component=3Dcom.cra.project</span></font><font
color=3Dblack
color:black'> workspace.root=3DC:/Documents and
Settings/jcampolongo/workspace</span></font><font size=3D2 =
color=3Dblack
color:black'> =
..project_1.0.1-osgi.bundle/temp</span></font><font
color=3Dblack
color:black'> =
buckminster.home=3DC:\dev\Project\trunk\Metronome-Project\</span ></font><=
font
color=3Dblack
color:black'>
ra.project_1.0.1-osgi.bundle/build</span></font><font
color=3Dblack
color:black'> localhost=3Djcampolongo-dt1</span></font><font =
size=3D2
color=3Dblack
color:black'> =
buckminster.component.type=3Dosgi.bundle</span></font><font
color=3Dblack
color:black'> buckminster.version.type=3DOSGi</span></font><font =
size=3D2
color=3Dblack
color:black'> buckminster.version=3D1.0.1</span></font><font =
size=3D2
color=3Dblack
color:black'> target.nl=3Den_US</span></font><font size=3D2 =
color=3Dblack
color:black'> target.ws=3Dwin32</span></font><font size=3D2 =
color=3Dblack
color:black'> eclipse.home=3DC:\eclipse</span></font><font =
size=3D2
color=3Dblack
color:black'> target.os=3Dwin32</span></font><font size=3D2 =
color=3Dblack
color:black'> =
target.location=3DC:\dev\Project\trunk\target_platform</span ></font><font=
color=3Dblack
color:black'>[end =
color=3Dblack
color:black'>Action com.cra.project:osgi.bundle$1.0.1#OSGi#bundle.jar =
using 'up
to date' policy COUNT: Rebuild needed: File count(0) < =
expected(1)</span></font><font
color=3Dblack
com.cra.project:osgi.bundle$1.0.1#OSGi#bundle.jar]</span></font ><font
color=3Dblack
color:black'> Product alias =3D action.output</span></font><font =
size=3D2
color=3Dblack
color:black'> Product base =3D =
${buckminster.output}\jar\</span></font><font
color=3Dblack
color=3Dblack
color:black'> =
color=3Dblack
color:black'> =
color=3Dblack
color=3Dblack
color:black'>
color=3Dblack
color:black'> =
font
color=3Dblack
color:black'>
color=3Dblack
size=3D2
color=3Dblack
color:black'> =
color=3Dblack
size=3D2
color=3Dblack
size=3D2
color=3Dblack
color=3Dblack
color=3Dblack
size=3D2
color=3Dblack
color=3Dblack
color:black'> =
color=3Dblack
color:black'>[end =
font-family:Arial'>Joseph Campolongo</span></font><o:p></o:p></p>
font-family:Arial'>Charles River Analytics, =
Inc.</span></font><o:p></o:p></p>
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV> </DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New">
<FONT FACE=3D"Arial" SIZE=3D"1">THIS MESSAGE IS INTENDED FOR THE USE OF =
THE PERSON TO WHOM IT IS ADDRESSED. IT MAY CONTAIN INFORMATION THAT IS =
PRIVILEGED, CONFIDENTIAL AND EXEMPT FROM DISCLOSURE UNDER APPLICABLE =
LAW. If you are not the intended recipient, your use of this message for =
any purpose is strictly prohibited. If you have received this =
communication in error, please delete the message and notify the sender =
so that we may correct our records.</FONT>
</DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New"> </DIV>
<DIV STYLE=3D"FONT-SIZE: 9pt; FONT-FAMILY: Courier New"></DIV>
</DIV></BODY></HTML>
------_=_NextPart_001_01C8EB45.21D6B0BD--
Re: [buckminster-dev] Plugin dependencies and cspex file [message #22406 is a reply to message #22380] |
Mon, 21 July 2008 11:35  |
Hi Joseph,
I think that what you see is all due to actions and their prerequisites.
You build some action that has prerequisites on other actions in other
bundles. If you examine those prerequisites more carefully, you will see
that the bundle where you add the cspex automatically adds them when you
add the dependency to the manifest.mf.
If you just add the dependency manually without adding any prerequisites
to an action that you execute, well, then it's required that the
component exists (i.e. resolution will work) but there's no reason for
it to be built. The actions that you execute have no action prerequisite
chain that ever reaches the bundle in question.
You can add this of course, by altering some of the groups or actions
that exists in the generated cspec.
I think the best way to really understand what's going on is to take a
look at the generated XML of a bundle cspec and pay specific attention
to the prerequisites and groups.
Thomas Hallgren
Joseph Campolongo wrote:
> Just to re-iterate, the ‘View CSpec’ action give me a cspec file that
> <cs:dependencies>
> <cs:dependency name="OSGi_Dependency"
> componentType="osgi.bundle" versionDesignator="1.0.0" versionType="OSGi"/>
> </cs:dependencies>
> Then, running the project with debug turned on, I don’t see anything
> the manifest.mf, I still don’t get the dependency being built. Only if
> I’m guessing that I’m doing something wrong somewhere, but it is opaque
> target.arch=x86
> PROJECT_Runtime=c:\Project_metronome
> buckminster.component=com.cra.project
> workspace.root=C:/Documents and Settings/jcampolongo/workspace
> buckminster.temp=C:/DOCUME~1/JCAMPO~1/LOCALS~1/Temp/buckmins ter/com.cra.project_1.0.1-osgi.bundle/temp
> buckminster.home=C:\dev\Project\trunk\Metronome-Project\
> buckminster.output=C:/DOCUME~1/JCAMPO~1/LOCALS~1/Temp/buckmi nster/com.cra.project_1.0.1-osgi.bundle/build
> localhost=jcampolongo-dt1
> buckminster.component.type=osgi.bundle
> buckminster.version.type=OSGi
> buckminster.version=1.0.1
> target.nl=en_US
> target.ws=win32
> eclipse.home=C:\eclipse
> target.os=win32
> target.location=C:\dev\Project\trunk\target_platform
> Product alias = action.output
> Product base = ${buckminster.output}\jar\
> target.arch=x86
> target.nl=en_US
> target.ws=win32
> target.os=win32
> Joseph Campolongo
> records.
Re: [buckminster-dev] Plugin dependencies and cspex file [message #22449 is a reply to message #22380] |
Hi Joseph,
Thomas Hallgren
> <cs:dependencies>
> </cs:dependencies>
> target.arch=x86
> target.nl=en_US
> target.ws=win32
> target.os=win32
> target.arch=x86
> target.nl=en_US
> target.ws=win32
> target.os=win32
> Joseph Campolongo
> records.
Current Time: Fri Apr 25 01:41:30 EDT 2025
Powered by FUDForum. Page generated in 0.03460 seconds
