Re: Possible to disable the navigation bar in the webviewer? [message #229185 is a reply to message #229057] |
Wed, 21 March 2007 21:05 |
Paal Espen Reinertsen wrote:
> If you don't do anything specific about the page breaking the report will be
> shown as 1 page in the webviewer.
> independent of long the the report actually is. (In the PDF-format the page
> breaking is perfect.)
> The web-viewer shows a navigation bar on top where it is possible to jump to
> a specified page number.
> This is totally unecessary and confusing when the webviewer shows the report
> as 1 page.
> So is it possible to disable the navigation bar in the webviewer to avoid
> confused users?
> Thanks!
> Pal Espen Reinertsen
Yes. You have a couple of choices modify the JSP pages that contain the
viewer in the \webcontent\birt\pages\layout directory, just use the /run
mapping instead of the frameset mapping, or use the 2.2M5 tag libraries.
The Viewer tag has an attribute to turn of the nav bar.
Jason
FUDForum. Page generated in 0.03732 seconds
