Home » Eclipse Projects » Babel » Re: how to internationalize a product-file
Re: how to internationalize a product-file [message #22315] |
Thu, 23 October 2008 12:35  |
Matthias,
I'm not sure, but maybe folks on the Babel newsgroup will know the
answer if no one here does. I've added it to the "to" list of the reply.
Matthias Droste wrote:
> I'm just trying to internationalize an RCP-App. I'm using the approach
> to put all the properties-files into a fragment and for java-Files,
> XML-Files and the plug-in/manifest-file everything has worked fine.
> But how can I adapt the .product-file to multiple languages?
> Especially items like the Launcher Name and the About Dialog's text
> should be translatable.
> I've tried something like this:
> bla.product: <launcher name="%product.LauncherName">
> bla.properties: product.LauncherName = bla Product
> But Eclipse just shows the key instead of the value.
> Do I have to create a product for each language or is there some
> better way?
> Matthias
Re: how to internationalize a product-file [message #22587 is a reply to message #22456] |
Mon, 03 November 2008 02:57   |
Originally posted by: matthias-droste.gmx.net
yes, thank, it works.
But the drawback is that this actually means that you have to copy the
product and don't (automatically) have the nice properties-file that you
can give to an external translator.
But at least the product's clean and tidy in the respective nl-folder.
Antoine Toulme schrieb:
> Matthias I think there is another way for those files.
> Look up that article:
> http://www.eclipse.org/articles/Article-Speak-The-Local-Lang uage/article.html
> Look at the picture:
> You can place your files like this:
> com.matthias.nl1.fragment
> nl
> fr
> CA
> something.product
> Let me know if it works.
> Antoine
> Ed Merks wrote:
>> Matthias,
>>> Hi,
>>> approach to put all the properties-files into a fragment and for
>>> java-Files, XML-Files and the plug-in/manifest-file everything has
>>> worked fine.
>>> better way?
>>> Thanks,
>>> Matthias
Re: how to internationalize a product-file [message #22631 is a reply to message #22587] |
Mon, 03 November 2008 15:27   |
Originally posted by: atoulme.intalio.com
Not sure that will be ever possible, but if you think that's important,
please file a bug to PDE and see if they like the idea.
Antoine
>> nl
>> fr
>> CA
>> something.product
>> Thanks,
>> Antoine
>> Ed Merks wrote:
>>> Matthias,
>>>> Hi,
>>>> worked fine.
>>>> better way?
>>>> Thanks,
>>>> Matthias
Re: how to internationalize a product-file [message #22674 is a reply to message #22587] |
Wed, 05 November 2008 07:45  |
Just for future use a better solution to the problem:
By pressing Synchronize in the product-UI some of the product's entries
(e.g. the about-text) end up in the application's plugin.xml. These
entries can be translated using properties.
Example:
file my.product:
<aboutInfo>
<text>
%product.branding.text
</text>
</aboutInfo>
file plugin.xml:
<extension
id="product"
point="org.eclipse.core.runtime.products">
<product...>
<property
name="aboutText"
value="%product.branding.text1">
</property>
file: plugin.properties:
product.branding.text1 = some about text
Matthias Droste schrieb:
>> nl
>> fr
>> CA
>> something.product
>> Thanks,
>> Antoine
>> Ed Merks wrote:
>>> Matthias,
>>> reply.
>>>> Hi,
>>>> worked fine.
>>>> better way?
>>>> Thanks,
>>>> Matthias
Re: how to internationalize a product-file [message #575380 is a reply to message #22315] |
Fri, 24 October 2008 18:51  |
nl
fr
CA
something.product
Antoine
Ed Merks wrote:
> Matthias,
>> better way?
>> Thanks,
>> Matthias
Re: how to internationalize a product-file [message #575461 is a reply to message #22456] |
> nl
> fr
> CA
> something.product
> Antoine
> Ed Merks wrote:
>> Matthias,
>>> Hi,
>>> worked fine.
>>> better way?
>>> Thanks,
>>> Matthias
Re: how to internationalize a product-file [message #575503 is a reply to message #22587] |
Antoine
>> nl
>> fr
>> CA
>> something.product
>> Thanks,
>> Antoine
>> Ed Merks wrote:
>>> Matthias,
>>>> Hi,
>>>> worked fine.
>>>> better way?
>>>> Thanks,
>>>> Matthias
Re: how to internationalize a product-file [message #575535 is a reply to message #22587] |
Example:
file my.product:
<aboutInfo>
<text>
</text>
</aboutInfo>
file plugin.xml:
<extension
id="product"
<product...>
<property
name="aboutText"
</property>
>> nl
>> fr
>> CA
>> something.product
>> Thanks,
>> Antoine
>> Ed Merks wrote:
>>> Matthias,
>>> reply.
>>>> Hi,
>>>> worked fine.
>>>> better way?
>>>> Thanks,
>>>> Matthias
Current Time: Sun Oct 19 13:52:01 EDT 2025
Powered by FUDForum. Page generated in 0.04024 seconds
