Home » Eclipse Projects » Plugin Development Environment (PDE) » p2'izing an application takes too long
p2'izing an application takes too long [message #22158] Mon, 15 September 2008 18:13 Go to next message
Ketan Padegaonkar is currently offline Ketan PadegaonkarFriend
I'm p2'izing an application using the below mentioned command line argument.
The command takes a few minutes to run, and seems to be talking to the
eclipse.org server for something. I'm sure I'm doing something wrong
here. Is there any way I could speed this up?
The eclipse folder contains the classic 3.4-sdk.
java -classpath
eclipse-sdk-3.4/plugins/org.eclipse.equinox.launcher_${eclip se.launcher.version}.jar
org.eclipse.equinox.launcher.Main
-application org.eclipse.equinox.p2.director.app.application
-nosplash --launcher.suppressErrors -consoleLog
-flavor tooling
-installIU com.thoughtworks.twist.eclipse.ui.application
-version 1.0.0.qualifier
-profile TwistProfile
-product
-profileProperties org.eclipse.update.install.features=true
-metadataRepository file:/twist/build/src/repo
-artifactRepository file:/twist/build/src/repo
-destination file:/twist/build/src/installer
-bundlepool file:/twist/build/src/installer
-vmargs -Declipse.p2.data.area=/twist/build/src/installer/p2
Ketan
Re: p2'izing an application takes too long [message #22443 is a reply to message #22158] Tue, 16 September 2008 16:05 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241430
The director application is considering all the repositories it knows
about. The Eclipse SDK ships prepopulated with the ganymede repos in
its preferences. Try deleting
eclipse/configuration/.settings/org.eclipse.equinox.p2.*.pre fs before
running the director.
-Andrew
Ketan Padegaonkar wrote:
> argument.
> java -classpath
> -flavor tooling
> -product
> Ketan
Re: p2'izing an application takes too long [message #22525 is a reply to message #22443] Wed, 17 September 2008 04:09 Go to previous message
Andrew Niefer wrote:
> See
Thanks that fixed the problem.
-- Ketan
Re: p2'izing an application takes too long [message #580557 is a reply to message #22158] Tue, 16 September 2008 16:05 Go to previous message
See
-Andrew
> argument.
> java -classpath
> -flavor tooling
> -product
> Ketan
Re: p2'izing an application takes too long [message #580618 is a reply to message #22443] Wed, 17 September 2008 04:09 Go to previous message
> See
-- Ketan
Previous Topic:memory snapshots of eclipse plugins
Next Topic:eclipse slows down (start-up, save manifest, save built.properties, open/close plug-in projects)
Current Time: Fri Dec 27 00:25:08 GMT 2024
Powered by FUDForum. Page generated in 0.03685 seconds
