Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Query regarding DLTK JRubySourceParser
Query regarding DLTK JRubySourceParser [message #21963] Tue, 01 April 2008 23:50 Go to next message
Originally posted by: pankaj.tolani.gmail.com
--------------020302090608020006010100
I am interested in using DLTK JRubySourceParser in my application for
Ruby. I have managed to use that in isolation. But I wish to know if I
can achieve more.
Here is what I wish to
A.rb
require "java"
load "B"
class A
def a
end
end
B.rb
class B
def b
end
end
Now I start with A.rb, I want the declarations in Ruby files I depend on
B.rb to be included as part of the ModuleDeclaration I get at the end of
the parse step. Is that possible? Essentially just like C preprocessor,
all included files should be compiled in.
thanks,
pankaj
P.S. I have attached the file which shows how I do the parsing.
name="NewAction.java"
Content-Disposition: inline;
filename="NewAction.java"
package dltk.ruby.source.parser.popup.actions;
import java.io.BufferedReader;
import java.io.FileReader;
import java.io.IOException;
import java.util.HashMap;
import java.util.Map;
import org.eclipse.core.resources.IFile;
import org.eclipse.dltk.ast.declarations.ModuleDeclaration;
import org.eclipse.dltk.compiler.SourceElementRequestVisitor;
import org.eclipse.dltk.compiler.problem.DLTKProblemReporter;
import org.eclipse.dltk.compiler.problem.DefaultProblemFactory;
import org.eclipse.dltk.core.SourceParserUtil;
import org.eclipse.dltk.core.ISourceModuleInfoCache.ISourceModuleIn fo;
import org.eclipse.jface.action.IAction;
import org.eclipse.jface.viewers.ISelection;
import org.eclipse.jface.viewers.IStructuredSelection;
import org.eclipse.ui.IActionDelegate;
import org.eclipse.ui.IObjectActionDelegate;
import org.eclipse.ui.IWorkbenchPart;
public class NewAction implements IObjectActionDelegate {
ISelection selection;
* Constructor for Action1.
public NewAction() {
super();
* @see IObjectActionDelegate#setActivePart(IAction, IWorkbenchPart)
public void setActivePart(IAction action, IWorkbenchPart targetPart) {
* @see IActionDelegate#run(IAction)
public void run(IAction action) {
/*Shell shell = new Shell();
MessageDialog.openInformation(
shell,
"Parser Plug-in",
"New Action was executed.");*/
final IFile selectedFile = (IFile) ((IStructuredSelection) this.selection).getFirstElement();
parseSourceModule(selectedFile);
private void parseSourceModule(IFile selectedFile) {
char[] filename = selectedFile.getFullPath().toString().toCharArray();
StringBuilder fileContents = new StringBuilder();
try {
BufferedReader in = new BufferedReader(new FileReader(selectedFile.getRawLocation().toFile()));
String str;
while ((str = in.readLine()) != null) {
fileContents.append(str);
fileContents.append('\n');
} catch (IOException e) {
e.printStackTrace();
char[] contents = fileContents.toString().toCharArray();
DLTKProblemReporter problemReporter = new DLTKProblemReporter(selectedFile, new DefaultProblemFactory());
/*ISourceParser sourceParserById = SourceParserManager.getInstance().getSourceParserById(getPar serId());
ModuleDeclaration moduleDeclaration = sourceParserById.parse(filename, contents, problemReporter);*/
ModuleDeclaration moduleDeclaration = SourceParserUtil.getModuleDeclaration(filename, contents, getNatureId(), problemReporter, astCache);
SourceElementRequestVisitor requestor = createVisitor();
try {
moduleDeclaration.traverse(requestor);
} catch (Exception e) {
* @see IActionDelegate#selectionChanged(IAction, ISelection)
public void selectionChanged(IAction action, ISelection selection) {
this.selection = selection;
private String getParserId() {
return "org.eclipse.dltk.ruby.parser.jrubySourceParser";
private String getNatureId() {
return "org.eclipse.dltk.ruby.core.nature";
protected SourceElementRequestVisitor createVisitor() {
return new MyRubySourceElementRequestVisitor(new MySourceElementRequestor());
private static class SourceModuleInfo implements ISourceModuleInfo {
private Map map;
public Object get(Object key) {
if (map == null) {
return null;
return map.get(key);
public void put(Object key, Object value) {
if (map == null) {
map = new HashMap();
map.put(key, value);
public void remove(Object key) {
if (map != null) {
map.remove(key);
public boolean isEmpty() {
if( this.map == null ) {
return true;
return this.map.isEmpty();
ISourceModuleInfo astCache = new SourceModuleInfo();
--------------020302090608020006010100--
Re: Query regarding DLTK JRubySourceParser [message #22185 is a reply to message #21963] Tue, 08 April 2008 02:57 Go to previous message
If you need specific load only support you could do following:
Write AST visitor to visit source module and process all load statements.
For each load statement you need to parse appropriate source module and include it contents.
Please see following classes for references:
ASTVisitor, CallExpression.
Andrei Sobolev.
> can achieve more.
> A.rb
> require "java"
> load "B"
> class A
> def a
> end
> end
> B.rb
> class B
> def b
> end
> end
> thanks,
> pankaj
Previous Topic:Signature change for IBuildpathContainer.getBuildpathEntries()
Next Topic:DLTK IDE Guide examples - missing getTextTools?
Current Time: Sat Oct 25 18:28:40 EDT 2025
Powered by FUDForum. Page generated in 0.02982 seconds
