Home » Archived » BIRT » AmountinWords Feature in Birt
AmountinWords Feature in Birt [message #224672] Tue, 13 March 2007 11:28 Go to next message
Originally posted by: harikrishnan_j2003.rediffmail.com
Sir,
I am designing a Invoice Report where i have to convert the
Final Amount in Words for instance 1200 as One Thousand and Two Hundred
Only.Is There is any builtin Function or any other way to achieve
this.kindly help
Thankyou
Harikrishnan J.
Re: AmountinWords Feature in Birt [message #224807 is a reply to message #224672] Tue, 13 March 2007 13:30 Go to previous messageGo to next message
Harikrishnan wrote:
> Sir,
> this.kindly help
> Thankyou
> Harikrishnan J.
I got this example from
http://javascript.about.com/library/bltoword.htm
Attached is a report that takes a float parameter that uses this
function to convert.
Jason
<!-- Written by Eclipse BIRT 2.0 -->
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.6"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.1.2.v20070205-1728 Build &lt;20070205-1728></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2006 &lt;&lt;Your Company
Name here>></property>
<parameters>
<scalar-parameter name="NewParameter" id="4">
<property name="valueType">static</property>
<property name="dataType">float</property>
<property name="controlType">text-box</property>
<property name="defaultValue">1000</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<data id="5">
<list-property name="boundDataColumns">
<structure>
<property name="name">data item</property>
<expression name="expression">// Convert numbers to
words
// copyright 25th July 2006, by Stephen Chapman http://javascript.about.com
// permission to use this Javascript on your web page is granted
// provided that all of the code (including this copyright notice) is
// used exactly as shown (you can change the numbering system if you wish)
// American Numbering System
var th = ['','thousand','million', 'billion','trillion'];
// uncomment this line for English Number System
// var th = ['','thousand','million', 'milliard','billion'];
var dg = ['zero','one','two','three','four',
'five','six','seven','eight','nine'];
var tn = ['ten','eleven','twelve','thirteen',
'fourteen','fifteen','sixteen', 'seventeen','eighteen','nineteen'];
var tw = ['twenty','thirty','forty','fifty',
'sixty','seventy','eighty','ninety'];
function toWords(s){
//s = s.replace(/[\, ]/g,'');
if (s != String(parseFloat(s))) return 'not a number';
s=String(parseFloat(s));
var x = s.indexOf('.');
if (x == -1) x = s.length;
if (x > 15) return 'too big';
var n = s.split('');
var str = '';
var sk = 0;
for (var i=0;
i &lt; x;
i++) {if ((x-i)%3==2) {if (n[i] == '1') {str += tn[Number(n[i+1])] + ' ';
i++;
sk=1;
} else if (n[i]!=0) {str += tw[n[i]-2] + ' ';
sk=1;
}} else if (n[i]!=0) {str += dg[n[i]] +' ';
if ((x-i)%3==0) str += 'hundred ';
sk=1;
} if ((x-i)%3==1) {if (sk) str += th[(x-i-1)/3] + ' ';
sk=0;
}} if (x != s.length) {
var y = s.length;
str += 'point ';
for (var i=x+1;
i&lt;y;
i++) str += dg[n[i]] +' ';
} return str.replace(/\s+/g,' ');
xyz = toWords(params["NewParameter"]);</expression>
<property name="dataType">any</property>
</structure>
</list-property>
<property name="resultSetColumn">data item</property>
</data>
</body>
</report>
Re: AmountinWords Feature in Birt [message #230669 is a reply to message #224807] Tue, 27 March 2007 05:41 Go to previous message
Sir,
Thankyou for your Answer it works well.
Thankyou
Harikrishnan J.
Previous Topic:Change XML file path in XML Data Source/Set
Next Topic:MYSQL Connection Refused
Current Time: Sun Nov 02 19:46:04 EST 2025
Powered by FUDForum. Page generated in 0.03485 seconds
