Error occured when exporting c/c++ index: map failed [message #224509] |
Sun, 05 October 2008 06:49 |
Originally posted by: mofliwsb.yahoo.com
I created a C++ makefile project in the Windows version of Eclipse on
existing source code, which has minillions line of code.
The source code is actually located on a linux server and the code directory
on the server is mapped to a Windows drive using Samba.
It took about several hours for the C/C++ indexer to finish when the option
of "index all files" is selected.
Now I want to export the project's C++ index, because I want to access the
same project on another Windows machine, which has the same Samba mapping,
so that I can simply import the index without re-building the index.
Unfortuenately, an error occured when I tried to export the index. The error
message popped out is: "Errors occured while exportign index", more detailed
error message is even simple: "map failed". Can anyone help me identify the
cause of error and how to get around it?
I tried to export the index of another project on the same linux server
which is much smaller, the export went well without any problem.
Sam
FUDForum. Page generated in 0.06388 seconds
