Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Signature change for IBuildpathContainer.getBuildpathEntries()
Signature change for IBuildpathContainer.getBuildpathEntries() [message #21829] Mon, 31 March 2008 21:35 Go to next message
Shelby Sanders is currently offline Shelby SandersFriend
All,
Why has IBuildpathContainer.getBuildpathEntries() been overloaded to expect
a parameter of IScriptProject? Also, why was the original, no-parameter
version retained rather than removed, since DLTK is still in beta?
Are IBuildpathContainer instances expected to be reusable across projects
now? If so, why don't the other methods accept an IScriptProject as well?
Thank You,
Shelby Sanders
Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #21873 is a reply to message #21829] Tue, 01 April 2008 05:12 Go to previous messageGo to next message
Andrei Sobolev is currently offline Andrei SobolevFriend
Member
Hi Shelby,
This allows per project customization of interpreter container, via org.eclipse.dltk.core.interpreterContainerExtension
extension point.
For example for tcl project in interpreter container entry we hold list of tcl package names, used in project. So each
project could contain different set of interpreter libraries.
You are right, I've removed old method. Thanks.
No they are not expected to be reusable.
Andrei Sobolev.
Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #21918 is a reply to message #21873] Tue, 01 April 2008 16:57 Go to previous messageGo to next message
What about the other methods?
I would expect at least getDescription() and getBuiltinProvider() to have
respective output based on the associated project as well.
> Hi Shelby,
> extension point.
> Best regards,
> Andrei Sobolev.
Thank You,
Shelby Sanders
Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #22011 is a reply to message #21918] Wed, 02 April 2008 09:51 Go to previous messageGo to next message
Member
Hi Shelby,
Sure. I've added parameter to this methods.
Andrei Sobolev.
>> Hi Shelby,
>> extension point.
>> Best regards,
>> Andrei Sobolev.
> Thank You,
> Shelby Sanders
Re: Signature change for IBuildpathContainer.getBuildpathEntries() [message #22055 is a reply to message #22011] Wed, 02 April 2008 17:03 Go to previous message
Cool. Thanks, Andrei.
> Hi Shelby,
> Best regards,
> Andrei Sobolev.
>>> Hi Shelby,
>>> extension point.
>>> tcl
>>> Best regards,
>>> Andrei Sobolev.
>> Thank You,
>> Shelby Sanders
Thank You,
Shelby Sanders
Previous Topic:tcl debugging with dltk
Next Topic:Query regarding DLTK JRubySourceParser
Current Time: Thu Dec 26 16:48:23 GMT 2024
Powered by FUDForum. Page generated in 0.04076 seconds
