Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP 4.0 perfmonagent problem
TPTP 4.0 perfmonagent problem [message #21754] Tue, 12 July 2005 02:43 Go to next message
Originally posted by: varaya.syamanond.centrelink.gov.au
Hi all,
I'm trying to work through launching PerfMon agent and I'm not sure if
it's even monitoring anything at all. When I opened the Agent Control
view, there are no data in there. Also, I can't open of the Statistics
views. Can you please point me in the right direction?
Thank you :-)
Sylvia
Re: TPTP 4.0 perfmonagent problem [message #21843 is a reply to message #21754] Tue, 12 July 2005 07:11 Go to previous messageGo to next message
Hi Sylvia,
Once you launch the agent, what do you see in the Profiling Monitor?
Does the agent appear, with a pause symbol beside it? If so, remember
that you need to Start Monitoring the agent from the Profiling Monitor
in order to gather data or control the agent.
Finally, what version of TPTP are you using?
Thanks!
George
Sylvia S. wrote:
> Hi all,
> Thank you :-)
> Sylvia
Re: TPTP 4.0 perfmonagent problem [message #21932 is a reply to message #21843] Tue, 12 July 2005 21:19 Go to previous messageGo to next message
Hi George,
I'm using TPTP version 4.0. Once I launch the agent, I do see the agent
appearing in the Profiling Monitor with the pause symbol beside it. I then
right click and select "Start Monitoring". The agent icon then has the
"monitoring" underneath it. However, when I select Agent Control view,
there are no data anywhere (ie. the agent icon just appear by itself in
the Agent Control view). Thank you very much for your help :-)
Sylvia
George Christelis wrote:
> Hi Sylvia,
> Thanks!
> George
> Sylvia S. wrote:
>> Hi all,
>> Thank you :-)
>> Sylvia
Re: TPTP 4.0 perfmonagent problem [message #21977 is a reply to message #21932] Wed, 13 July 2005 21:25 Go to previous message
Okie, I have decided to go back to Hyades v3.2.0 and I can get the
perfmonagent to launch and collect data properly now :-)
Sylvia
Sylvia S. wrote:
> Hi George,
> Sylvia
>> Hi Sylvia,
>> Thanks!
>> George
>> Sylvia S. wrote:
>>> Hi all,
>>> Thank you :-)
>>> Sylvia
Previous Topic:Installation problem
Next Topic:TPTP Platform Report - SWTGraphicViewer
Current Time: Fri Apr 25 01:16:44 EDT 2025
Powered by FUDForum. Page generated in 0.03208 seconds
