Re: IllegalAccessError while trying to compile with org.eclipse.jdt.internal.compiler.batch.Main... [message #222871 is a reply to message #222820] |
Mon, 23 January 2006 17:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: olivier_thomann.NOca.ibm.comSPAM
ted stockwell a écrit :
> My application works fine on Windows but fails on Linux.
> My application contains an embedded instance of the Tomcat web server
> that is configured to use the batch JDT compile for compiling JSPs.
> When I try to run on Linux I get the following stack trace...
> ----- Root Cause -----
> java.lang.IllegalAccessError: tried to access method
> org.eclipse.jdt.internal.compiler.batch.FileSystem.getClassp ath(Ljava/lang/String;Ljava/lang/String;ILorg/eclipse/jdt/in ternal/compiler/env/AccessRuleSet;)Lorg/eclipse/jdt/internal /compiler/batch/FileSystem$Classpath;
> from class org.eclipse.jdt.internal.compiler.batch.Main
> at
> org.eclipse.jdt.internal.compiler.batch.Main.addNewEntry(Mai n.java:2443)
> at
You should open a bug report against JDT/Core with build id, steps to
reproduce and as much information as possible.
Olivier
FUDForum. Page generated in 0.03736 seconds
