How to add new features MANUALLY? [message #222666] |
Thu, 16 October 2008 18:43 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mstev.ozone.com
Ok I could use the menu help-Software Updates->Find and install...
to add/update new features to an Eclipse installation.
However is there a way to add/update features manually?
Assume I have downloaded a *.zip file with a new feature.
Can I simply extract it to the Eclipse directory tree?
Is the new feature automatically recognized by a running Eclipse
or do I have to re-boot Eclipse?
Do I have (in addition to the copy operation) "register" somewhere the new/update feature
or does Eclipse recognize the add/update feature automatically?
Do I have to extract only the "plugin" sub-folder or the "features" sub-folder as well?
Pia
Re: How to add new features MANUALLY? [message #222672 is a reply to message #222666] |
Thu, 16 October 2008 22:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Pia
Yes you can extract the zip file in the eclipse directory structure.
Once extracted, eclipse doesn't recognize the feature automatically, you
need to reboot it.
Now thats the only thing to do about it.
You need to extract both the directories, plugin and features.
The way I do this, is something like this. I don't want to mess with my
eclipse installation. so i created a directory on C:\MyEclipsePlugins
(or anywhere) and extract my plugin there. Now to link the plugin to the
eclipse installation is via a link file.
So my directory structure looks something like this:
C:\Eclipse3.3
\links
myplugins.lnk
The "links" directory is not created by default, you need to create it.
Now the "myplugins.lnk" looks something like this (it would be just a
single line)
c:\MyEclipsePlugins\<your plugin name>
Advantage obviously is u can used this plugin in multiple eclipse
installations at the same time.
Atul
Re: How to add new features MANUALLY? [message #222678 is a reply to message #222666] |
Thu, 16 October 2008 22:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Pia
need to reboot it.
C:\Eclipse3.3
\links
myplugins.lnk
single line)
Atul
FUDForum. Page generated in 0.25834 seconds
