Home » Eclipse Projects » DTP » How to use modelbase standalone
How to use modelbase standalone [message #21687] Fri, 22 September 2006 06:32 Go to next message
Originally posted by: yavin.gmx.com
is it possible to use the SQL statement model in the modelbase
standalone? We are searching for a lib that gives the programmer an easy
API to create complex SQL statements without actualy writing SQL code.
Additionally it would be fantastic if the lib knows about the db schema
and could validate the SQL statement during creation.
Could we use some of the DTP parts for that approach? Do someone know an
alternative?
Regards, Kai
Re: How to use modelbase standalone [message #21732 is a reply to message #21687] Fri, 22 September 2006 20:26 Go to previous messageGo to next message
Originally posted by: jograham.sybase.com
Kai wrote:
> Hello,
> alternative?
> Regards, Kai
Hi Kai,
If by "standalone" you mean still in Eclipse with EMF but not the rest of
DTP (connectivity, SQL Dev), then the answer is "yes." The SQL model
consumes a JDBC connection, so, as long as you can provide that, you can
use the model. A SQL model instance for a given JDBC connection knows
about the meta-data, and the SQL Query model uses the SQL model. While
there is no automatic validation like you describe above, all of the
necessary pieces should be there to do so.
John Graham
Eclipse Data Tools Platform PMC Chair
Re: How to use modelbase standalone [message #21777 is a reply to message #21732] Mon, 25 September 2006 05:47 Go to previous message
Hey Graham,
thanks very much for your answer.
> of DTP (connectivity, SQL Dev), then the answer is "yes."
I mean standalone with all necessary dependencies like EMF but maybe not
in an Eclipse env.
> The SQL model
Okay that sounds good. Could you give me a short code example how to use
the model with a JDBC connection? I read the UML docs and the reference
but it seems I didn't hit the right pages.
THX is advance.
Re: How to use modelbase standalone [message #582391 is a reply to message #21687] Fri, 22 September 2006 20:26 Go to previous message
John Graham is currently offline John GrahamFriend
Kai wrote:
> Hello,
> alternative?
> Regards, Kai
Hi Kai,
John Graham
Re: How to use modelbase standalone [message #582412 is a reply to message #21732] Mon, 25 September 2006 05:47 Go to previous message
Kai is currently offline KaiFriend
Hey Graham,
in an Eclipse env.
> The SQL model
THX is advance.
Previous Topic:How to use modelbase standalone
Next Topic:Extending/Fixing DatabaseDefinitionImpl
Current Time: Thu Dec 26 16:59:16 GMT 2024
Powered by FUDForum. Page generated in 0.03381 seconds
