Home » Language IDEs » ServerTools (WTP) » Question about starting JBoss from within Eclipse
Question about starting JBoss from within Eclipse [message #222587] |
Mon, 06 October 2008 20:17 |
Adam Sandler![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mgoblue0970%40msn.com) Messages: 4 Registered: July 2009 |
Junior Member |
I have JBoss v.4.2.2 and have it installed in C:\jboss-4.2.2.GA\. I can
start the server from command line just fine. I cannot start the server
from within Eclipse (v.3.4.0) though -- which is why I'm posting here and
not the JBoss forum. It fails with a rather generic error which does not
describe a problem at all. Details follow...
At any rate, I've downloaded the latest WTP plug-in (from Help | Software
Updates) and all of the dependencies. From within Eclipse, I've gone to
Window | Preferences | Java | Installed JREs and made en entry for my Java
version installed in C:\jdk1.6.0. From Window | Preferences | Server |
Runtime Environments, I made an entry for my JBoss runtime: the home
directory is C:\jboss-4.2.2.GA and the JRE is jdk1.6.0.
From the Servers View, the Overview page has this info:
Server name: JBoss 4.2 Server
Host name: localhost
Runtime Environment: JBoss 4.2 Runtime
Deploy Directory: C:\jboss-4.2.2.GA\server\default\deploy
Temporary Deploy Directory:
C:\jboss-4.2.2.GA\server\default\tmp\jbosstoolsTemp
For login credentials, I've left the user and password fields both blank
and with 'admin' and got the same results.
In the Runtime Environment Configuration, here are the settings:
Name: JBoss 4.2 Server
Program arguments: --configuration=default
VM arguments: -Xms256m -Xmx512m -XX:MaxPermSize=256m
Working Directory: Other | C:\jboss-4.2.2.GA/bin
When I try to run the server I get this console output:
12:44:01,899 INFO [Server] Starting JBoss (MX MicroKernel)...
12:44:01,899 INFO [Server] Release ID: JBoss [Trinity] 4.2.2.GA (build:
SVNTag=JBoss_4_2_2_GA date=200710221139)
12:44:01,899 INFO [Server] Home Dir: C:\jboss-4.2.2.GA
12:44:01,899 INFO [Server] Home URL: file:/C:/jboss-4.2.2.GA/
12:44:01,899 INFO [Server] Patch URL: null
12:44:01,899 INFO [Server] Server Name: default
12:44:01,899 INFO [Server] Server Home Dir:
12:44:01,899 INFO [Server] Server Home URL:
file:/C:/jboss-4.2.2.GA/server/default/
12:44:01,899 INFO [Server] Server Log Dir:
C:\jboss-4.2.2.GA\server\default\log
12:44:01,899 INFO [Server] Server Temp Dir:
12:44:01,899 INFO [Server] Root Deployment Filename: jboss-service.xml
12:44:02,133 INFO [ServerInfo] Java version: 1.6.0,Sun Microsystems Inc.
12:44:02,133 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM
1.6.0-b105,Sun Microsystems Inc.
12:44:02,133 INFO [ServerInfo] OS-System: Windows XP 5.1,x86
12:44:02,305 INFO [Server] Core system initialized
and then starting the server fails with this message:
'Starting JBoss 4.2 Server' has encountered a problem. Server JBoss 4.2
Server failed to start.
Since that doesn't tell me jack, I went to
C:\jboss-4.2.2.GA\server\default\log and opened boot.log Here's what is
inside:
13:25:32,799 INFO [Server] Starting JBoss (MX MicroKernel)...
13:25:32,799 INFO [Server] Release ID: JBoss [Trinity] 4.2.2.GA (build:
13:25:32,799 DEBUG [Server] Using config:
org.jboss.system.server.ServerConfigImpl@1c99159
13:25:32,799 DEBUG [Server] Server type: class
org.jboss.system.server.ServerImpl
13:25:32,799 DEBUG [Server] Server loaded through:
org.jboss.system.server.NoAnnotationURLClassLoader
13:25:32,799 DEBUG [Server] Boot URLs:
file:/C:/jboss-4.2.2.GA/lib/endorsed/serializer.jar
file:/C:/jboss-4.2.2.GA/lib/endorsed/xalan.jar
file:/C:/jboss-4.2.2.GA/lib/endorsed/xercesImpl.jar
13:25:32,799 DEBUG [Server] file:/C:/jboss-4.2.2.GA/lib/jboss-jmx.jar
13:25:32,799 DEBUG [Server] file:/C:/jboss-4.2.2.GA/lib/concurrent.jar
13:25:32,799 DEBUG [Server] file:/C:/jboss-4.2.2.GA/lib/log4j-boot.jar
13:25:32,799 DEBUG [Server] file:/C:/jboss-4.2.2.GA/lib/jboss-common.jar
13:25:32,799 DEBUG [Server] file:/C:/jboss-4.2.2.GA/lib/jboss-system.jar
file:/C:/jboss-4.2.2.GA/lib/jboss-xml-binding.jar
13:25:32,799 INFO [Server] Home Dir: C:\jboss-4.2.2.GA
13:25:32,799 INFO [Server] Home URL: file:/C:/jboss-4.2.2.GA/
13:25:32,799 DEBUG [Server] Library URL: file:/C:/jboss-4.2.2.GA/lib/
13:25:32,799 INFO [Server] Patch URL: null
13:25:32,799 INFO [Server] Server Name: default
13:25:32,799 INFO [Server] Server Home Dir:
13:25:32,799 INFO [Server] Server Home URL:
13:25:32,799 INFO [Server] Server Log Dir:
13:25:32,799 DEBUG [Server] Server Data Dir:
C:\jboss-4.2.2.GA\server\default\data
13:25:32,799 INFO [Server] Server Temp Dir:
13:25:32,799 DEBUG [Server] Server Config URL:
file:/C:/jboss-4.2.2.GA/server/default/conf/
13:25:32,799 DEBUG [Server] Server Library URL:
file:/C:/jboss-4.2.2.GA/server/default/lib/
13:25:32,799 INFO [Server] Root Deployment Filename: jboss-service.xml
13:25:32,799 DEBUG [Server] Starting General Purpose Architecture (GPA)...
13:25:32,892 DEBUG [Server] Created MBeanServer:
org.jboss.mx.server.MBeanServerImpl@1551d7f[ defaultDomain='jboss' ]
13:25:32,908 DEBUG [Server] Boot url list:
[file:/C:/jboss-4.2.2.GA/server/default/conf/]
13:25:32,908 DEBUG [Server] Creating loader for URL:
13:25:32,908 DEBUG [RepositoryClassLoader] setRepository,
repository=org.jboss.mx.loading.UnifiedLoaderRepository3@134e4fb,
cl=org.jboss.mx.loading.UnifiedClassLoader3@1a52fdf{
url=file:/C:/jboss-4.2.2.GA/server/default/conf/ ,addedOrder=0}
13:25:32,908 DEBUG [UnifiedLoaderRepository3] Adding
13:25:33,033 DEBUG [Server] Failed to create xmbean for:
org.jboss.system.server.ServerInfo
13:25:33,033 INFO [ServerInfo] Java version: 1.6.0,Sun Microsystems Inc.
13:25:33,033 INFO [ServerInfo] Java VM: Java HotSpot(TM) Client VM
13:25:33,033 INFO [ServerInfo] OS-System: Windows XP 5.1,x86
13:25:33,033 DEBUG [ServerInfo] Full System Properties Dump
13:25:33,033 DEBUG [ServerInfo] java.runtime.name: Java(TM) SE Runtime
Environment
13:25:33,033 DEBUG [ServerInfo] jboss.server.base.dir:
13:25:33,033 DEBUG [ServerInfo] java.protocol.handler.pkgs:
org.jboss.net.protocol
13:25:33,033 DEBUG [ServerInfo] sun.boot.library.path:
C:\jdk1.6.0\jre\bin
13:25:33,033 DEBUG [ServerInfo] jboss.server.lib.url:
13:25:33,033 DEBUG [ServerInfo] java.vm.version: 1.6.0-b105
13:25:33,033 DEBUG [ServerInfo] javax.management.builder.initial:
org.jboss.mx.server.MBeanServerBuilderImpl
13:25:33,033 DEBUG [ServerInfo] java.vm.vendor: Sun Microsystems Inc.
13:25:33,033 DEBUG [ServerInfo] java.vendor.url: http://java.sun.com/
13:25:33,033 DEBUG [ServerInfo] path.separator: ;
13:25:33,033 DEBUG [ServerInfo] java.vm.name: Java HotSpot(TM) Client
VM
13:25:33,033 DEBUG [ServerInfo] file.encoding.pkg: sun.io
13:25:33,033 DEBUG [ServerInfo] user.country: US
13:25:33,033 DEBUG [ServerInfo] sun.java.launcher: SUN_STANDARD
13:25:33,033 DEBUG [ServerInfo] sun.os.patch.level: Service Pack 2
13:25:33,033 DEBUG [ServerInfo] java.vm.specification.name: Java
Virtual Machine Specification
13:25:33,033 DEBUG [ServerInfo] user.dir: C:\jboss-4.2.2.GA\bin
13:25:33,033 DEBUG [ServerInfo] jboss.server.base.url:
13:25:33,033 DEBUG [ServerInfo] java.runtime.version: 1.6.0-b105
13:25:33,033 DEBUG [ServerInfo] java.awt.graphicsenv:
sun.awt.Win32GraphicsEnvironment
13:25:33,033 DEBUG [ServerInfo] java.endorsed.dirs:
C:\jdk1.6.0\jre\lib\endorsed
13:25:33,033 DEBUG [ServerInfo] os.arch: x86
13:25:33,033 DEBUG [ServerInfo] java.io.tmpdir:
C:\DOCUME~1\widdicc\LOCALS~1\Temp\
13:25:33,033 DEBUG [ServerInfo] line.separator:
13:25:33,033 DEBUG [ServerInfo] jbossmx.loader.repository.class:
13:25:33,033 DEBUG [ServerInfo] java.vm.specification.vendor: Sun
Microsystems Inc.
13:25:33,033 DEBUG [ServerInfo] user.variant:
13:25:33,033 DEBUG [ServerInfo] os.name: Windows XP
13:25:33,033 DEBUG [ServerInfo] jboss.bind.address: 127.0.0.1
13:25:33,033 DEBUG [ServerInfo] jboss.server.temp.dir:
13:25:33,033 DEBUG [ServerInfo] jboss.home.dir: C:\jboss-4.2.2.GA
13:25:33,033 DEBUG [ServerInfo] sun.jnu.encoding: Cp1252
13:25:33,033 DEBUG [ServerInfo] java.library.path:
C:\jdk1.6.0\bin;.;C:\WINDOWS\Sun\Java\bin;C:\WINDOWS\system3 2;C:\WINDOWS;C:/jre1.6.0/bin/client;C:/jre1.6.0/bin;C:\oracl exe\app\oracle\product\10.2.0\server\bin;D:\oracle\Ora10g\bi n;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C: \Program
Files\Common Files\Roxio Shared\DLLShared\;C:\Program
Files\Intel\DMIX;C:\Program Files\Common Files\Autodesk Shared\;C:\Program
Files\Autodesk\DWG TrueView\;C:\Program Files\NTRU Cryptosystems\NTRU TCG
Software Stack\bin\;C:\Program Files\Rational\common;C:\Program
Files\Rational\ClearCase\bin;C:\Program Files\ATI
Technologies\ATI.ACE\;C:\jdk1.6.0\bin;C:\Program
Files\apache-maven-2.0.9\bin;C:\Program Files\Common Files\Adaptec
Shared\System;C:\oraclexe\app\oracle\product\10.2.0\server\j dbc\lib\ojdbc14.jar;C:\jboss-4.2.2.GA\jboss-4.2.2.GA\bin;.
13:25:33,033 DEBUG [ServerInfo] jboss.server.home.dir:
13:25:33,033 DEBUG [ServerInfo] java.class.version: 50.0
13:25:33,033 DEBUG [ServerInfo] java.specification.name: Java Platform
API Specification
13:25:33,033 DEBUG [ServerInfo] sun.management.compiler: HotSpot
Client Compiler
13:25:33,033 DEBUG [ServerInfo] jboss.server.config.url:
13:25:33,033 DEBUG [ServerInfo] os.version: 5.1
13:25:33,033 DEBUG [ServerInfo] jboss.home.url:
13:25:33,033 DEBUG [ServerInfo] user.home: C:\Documents and
Settings\widdicc
13:25:33,033 DEBUG [ServerInfo] user.timezone: America/Denver
13:25:33,033 DEBUG [ServerInfo] java.awt.printerjob:
sun.awt.windows.WPrinterJob
13:25:33,033 DEBUG [ServerInfo] java.specification.version: 1.6
13:25:33,033 DEBUG [ServerInfo] file.encoding: Cp1252
13:25:33,033 DEBUG [ServerInfo] jboss.server.home.url:
13:25:33,033 DEBUG [ServerInfo] jboss.server.log.dir:
13:25:33,033 DEBUG [ServerInfo] user.name: widdicc
13:25:33,033 DEBUG [ServerInfo] java.class.path:
C:\jboss-4.2.2.GA\bin\run.jar
13:25:33,033 DEBUG [ServerInfo] jboss.lib.url:
13:25:33,033 DEBUG [ServerInfo] jboss.server.name: default
13:25:33,033 DEBUG [ServerInfo] java.vm.specification.version: 1.0
13:25:33,033 DEBUG [ServerInfo] sun.arch.data.model: 32
13:25:33,033 DEBUG [ServerInfo] java.home: C:\jdk1.6.0\jre
13:25:33,033 DEBUG [ServerInfo] java.specification.vendor: Sun
Microsystems Inc.
13:25:33,033 DEBUG [ServerInfo] user.language: en
13:25:33,033 DEBUG [ServerInfo] awt.toolkit: sun.awt.windows.WToolkit
13:25:33,033 DEBUG [ServerInfo] java.vm.info: mixed mode
13:25:33,033 DEBUG [ServerInfo] java.version: 1.6.0
13:25:33,033 DEBUG [ServerInfo] java.ext.dirs:
C:\jdk1.6.0\jre\lib\ext;C:\WINDOWS\Sun\Java\lib\ext
13:25:33,033 DEBUG [ServerInfo] jboss.server.data.dir:
13:25:33,033 DEBUG [ServerInfo] sun.boot.class.path:
C:\jdk1.6.0\jre\lib\resources.jar;C:\jdk1.6.0\jre\lib\rt.jar ;C:\jdk1.6.0\jre\lib\sunrsasign.jar;C:\jdk1.6.0\jre\lib\jsse .jar;C:\jdk1.6.0\jre\lib\jce.jar;C:\jdk1.6.0\jre\lib\charset s.jar;C:\jdk1.6.0\jre\classes
13:25:33,033 DEBUG [ServerInfo] java.vendor: Sun Microsystems Inc.
13:25:33,033 DEBUG [ServerInfo] file.separator: \
13:25:33,033 DEBUG [ServerInfo] java.vendor.url.bug:
http://java.sun.com/cgi-bin/bugreport.cgi
13:25:33,033 DEBUG [ServerInfo] sun.cpu.endian: little
13:25:33,033 DEBUG [ServerInfo] sun.io.unicode.encoding: UnicodeLittle
13:25:33,033 DEBUG [ServerInfo] java.rmi.server.hostname: 127.0.0.1
13:25:33,033 DEBUG [ServerInfo] sun.desktop: windows
13:25:33,033 DEBUG [ServerInfo] sun.cpu.isalist: pentium_pro+mmx
pentium_pro pentium+mmx pentium i486 i386 i86
13:25:33,049 DEBUG [Server] Created system MBean:
jboss.system:type=ServerInfo
13:25:33,049 DEBUG [Server] Failed to create xmbean for:
org.jboss.system.ServiceController
13:25:33,064 DEBUG [ServiceController] Controller MBean online
13:25:33,064 DEBUG [Server] Created system MBean:
jboss.system:service=ServiceController
13:25:33,142 DEBUG [Server] Created system XMBean:
jboss.system:service=MainDeployer
13:25:33,142 DEBUG [ServiceController] Creating service
13:25:33,142 DEBUG [MainDeployer] Creating
13:25:33,158 DEBUG [MainDeployer] Created jboss.system:service=MainDeployer
13:25:33,158 DEBUG [ServiceController] Creating dependent components for:
jboss.system:service=MainDeployer dependents are: []
13:25:33,158 DEBUG [ServiceController] starting service
13:25:33,158 DEBUG [MainDeployer] Starting
13:25:33,158 DEBUG [MainDeployer] Started jboss.system:service=MainDeployer
13:25:33,158 DEBUG [ServiceController] Starting dependent components for:
jboss.system:service=MainDeployer dependent components: []
13:25:33,158 DEBUG [Server] Shutdown hook added
13:25:33,189 DEBUG [Server] Created system XMBean:
jboss.system:service=JARDeployer
13:25:33,189 DEBUG [ServiceController] Creating service
13:25:33,189 DEBUG [JARDeployer] Creating jboss.system:service=JARDeployer
13:25:33,205 DEBUG [JARDeployer] Created jboss.system:service=JARDeployer
13:25:33,205 DEBUG [ServiceController] Creating dependent components for:
jboss.system:service=JARDeployer dependents are: []
13:25:33,205 DEBUG [ServiceController] starting service
13:25:33,205 DEBUG [JARDeployer] Starting jboss.system:service=JARDeployer
13:25:33,205 DEBUG [MainDeployer] Adding deployer:
org.jboss.deployment.JARDeployer@13f991
13:25:33,205 DEBUG [SuffixOrderHelper] Static suffix exists; ignoring
request for adding enhanced suffix: 700:.jar
13:25:33,205 DEBUG [JARDeployer] Started jboss.system:service=JARDeployer
13:25:33,205 DEBUG [ServiceController] Starting dependent components for:
jboss.system:service=JARDeployer dependent components: []
13:25:33,220 DEBUG [Server] Created system XMBean:
jboss.system:service=ServiceDeployer
13:25:33,220 DEBUG [ServiceController] Creating service
13:25:33,220 DEBUG [SARDeployer] Creating
13:25:33,220 DEBUG [SARDeployer] Created
13:25:33,220 DEBUG [ServiceController] Creating dependent components for:
jboss.system:service=ServiceDeployer dependents are: []
13:25:33,220 DEBUG [ServiceController] starting service
13:25:33,220 DEBUG [SARDeployer] Starting
13:25:33,220 DEBUG [MainDeployer] Adding deployer:
org.jboss.deployment.SARDeployer@1878144
13:25:33,220 DEBUG [SARDeployer] Started
13:25:33,220 DEBUG [ServiceController] Starting dependent components for:
jboss.system:service=ServiceDeployer dependent components: []
13:25:33,220 INFO [Server] Core system initialized
13:25:33,236 DEBUG [MainDeployer] Starting deployment of package:
file:/C:/jboss-4.2.2.GA/server/default/conf/jboss-service.xm l
13:25:33,236 DEBUG [MainDeployer] Starting deployment (init step) of
package at: file:/C:/jboss-4.2.2.GA/server/default/conf/jboss-service.xm l
13:25:33,236 DEBUG [MainDeployer] Copying
file:/C:/jboss-4.2.2.GA/server/default/conf/jboss-service.xm l ->
C:\jboss-4.2.2.GA\server\default\tmp\deploy\tmp63475jboss-se rvice.xml
13:25:33,236 DEBUG [MainDeployer] using deployer
13:25:33,299 DEBUG [SARDeployer] Found classpath element: [classpath: null]
13:25:33,299 DEBUG [SARDeployer] codebase URL is
13:25:33,299 DEBUG [SARDeployer] listing codebase for archives matching *
13:25:33,299 DEBUG [SARDeployer] URLLister class is
org.jboss.net.protocol.file.FileURLLister
13:25:33,314 DEBUG [SARDeployer] deployed classes for
file:/C:/jboss-4.2.2.GA/server/default/lib/activation.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/antlr.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/autonumber-plugin .jar
file:/C:/jboss-4.2.2.GA/server/default/lib/bcel.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/bindingservice-pl ugin.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/bsf.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/bsh-deployer.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/bsh.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/cglib.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-codec.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-collectio ns.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-httpclien t.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-logging.j ar
file:/C:/jboss-4.2.2.GA/server/default/lib/dom4j.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/ejb3-persistence. jar
file:/C:/jboss-4.2.2.GA/server/default/lib/el-api.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/hibernate-annotat ions.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/hibernate-entitym anager.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/hibernate3.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/hsqldb-plugin.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/hsqldb.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/javassist.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jaxen.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-cache-jdk50 .jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-common-jdbc -wrapper.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-ejb3x.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-hibernate.j ar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-j2ee.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-jaxrpc.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-jaxws.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-jca.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-jsr77.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-jsr88.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-management. jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-monitoring. jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-remoting-in t.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-remoting.ja r
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-saaj.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-serializati on.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-srp.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-transaction .jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss-vfs.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jboss.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossjta-integrat ion.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossjta.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossmq.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jbosssx.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossts-common.ja r
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossws-common.ja r
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossws-framework .jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossws-jboss42.j ar
file:/C:/jboss-4.2.2.GA/server/default/lib/jbossws-spi.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jmx-adaptor-plugi n.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jnpserver.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/joesnmp.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jpl-pattern.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jpl-util.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/jsp-api.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/log4j-snmp-append er.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/log4j.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/mail-plugin.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/mail.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/properties-plugin .jar
file:/C:/jboss-4.2.2.GA/server/default/lib/quartz.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/scheduler-plugin- example.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/scheduler-plugin. jar
file:/C:/jboss-4.2.2.GA/server/default/lib/servlet-api.jar
file:/C:/jboss-4.2.2.GA/server/default/lib/xmlentitymgr.jar
13:25:33,314 DEBUG [SARDeployer] about to copy 0 local directories
13:25:33,314 DEBUG [SARDeployer] looking for nested deployments in :
13:25:33,314 DEBUG [DeploymentInfo] createLoaderRepository from config:
LoaderRepositoryConfig(repositoryName:
JMImplementation:service=LoaderRepository,name=Default,
repositoryClassName: null, configParserClassName: null, repositoryConfig:
null)
13:25:33,314 DEBUG [RepositoryClassLoader] setRepository,
cl=org.jboss.mx.loading.UnifiedClassLoader3@b1074a{ url=null ,addedOrder=0}
13:25:33,314 DEBUG [UnifiedLoaderRepository3] Adding
13:25:33,314 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/activation.jar, to ucl:
org.jboss.mx.loading.UnifiedClassLoader3@b1074a{ url=null ,addedOrder=2}
13:25:33,345 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/antlr.jar, to ucl:
file:/C:/jboss-4.2.2.GA/server/default/lib/autonumber-plugin .jar, to ucl:
13:25:33,377 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/bcel.jar, to ucl:
file:/C:/jboss-4.2.2.GA/server/default/lib/bindingservice-pl ugin.jar, to
ucl: org.jboss.mx.loading.UnifiedClassLoader3@b1074a{ url=null
,addedOrder=2}
file:/C:/jboss-4.2.2.GA/server/default/lib/bsf.jar, to ucl:
file:/C:/jboss-4.2.2.GA/server/default/lib/bsh-deployer.jar, to ucl:
13:25:33,392 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/bsh.jar, to ucl:
13:25:33,392 DEBUG [ClassLoaderUtils] Multiple class loaders found for
pkg:
13:25:33,408 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/cglib.jar, to ucl:
13:25:33,423 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-codec.jar , to ucl:
13:25:33,455 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-collectio ns.jar, to
,addedOrder=2}
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-httpclien t.jar, to ucl:
file:/C:/jboss-4.2.2.GA/server/default/lib/commons-logging.j ar, to ucl:
13:25:33,470 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/dom4j.jar, to ucl:
13:25:33,486 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/ejb3-persistence. jar, to ucl:
file:/C:/jboss-4.2.2.GA/server/default/lib/el-api.jar, to ucl:
13:25:33,502 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/hibernate-annotat ions.jar, to
,addedOrder=2}
13:25:33,517 DEBUG [RepositoryClassLoader] Added url:
file:/C:/jboss-4.2.2.GA/server/default/lib/hibernate-entitym anager.jar, to
,addedOrder=2}
I'm not sure if that tells me much either. So, the question is, how can I
get JBoss to run from Eclipse without failing just by starting the server?
Suggestions are greatly appreciated. Thanks!
Current Time: Wed Jul 17 18:40:26 GMT 2024
Powered by FUDForum. Page generated in 0.03765 seconds
