Home » Language IDEs » AspectJ » Update manager can not differentiate between a development and an standard versi
Update manager can not differentiate between a development and an standard versi [message #21633] Thu, 15 May 2003 11:35 Go to next message
Arno Schmidmeier is currently offline Arno SchmidmeierFriend
I have used the updatemanager to deploy an development version on my
systems.
Now after AJDT 1.1.2 is out I would like to upgrade to the latest version.
Unfortunatly I do not have any update button anymore.
I expect, that this is because both of these versions have the same
version number. 1.1.2
If this assumption would be correct can we update the version numbering
for the development stream?
kind regards
Arno
Re: Update manager can not differentiate between a development and an standard versi [message #21678 is a reply to message #21633] Thu, 15 May 2003 15:23 Go to previous message
Originally posted by: clemas.hursley.ibm.com
> systems.
That is a good point, I will change the dev version to 1.1.3.
In fact, in the time it has taken me to compose this message - Adrian did
it for me - the dev version should now be at 1.1.3.
cheers,
Andy.
Re: Update manager can not differentiate between a development and an standard versi [message #567132 is a reply to message #21633] Thu, 15 May 2003 15:23 Go to previous message
Andrew Clement is currently offline Andrew ClementFriend
> systems.
cheers,
Andy.
Previous Topic:Update manager can not differentiate between a development and an standard versi
Next Topic:Inconsistency with AJDT
Current Time: Thu Dec 26 18:01:57 GMT 2024
Powered by FUDForum. Page generated in 0.03810 seconds
