Home » Newcomers » Newcomers » User Class Library
User Class Library [message #221845] Mon, 16 July 2007 20:58 Go to next message
Originally posted by: morrow_margaret.stvrain.k12.co.us
I'm trying to use a .class file that contains a number of methods. I've
created a number of different directory structures under both the
workspace and the project /lib/cs1 - cs1 is the package name. I've
added the class folder to the java build path, but neither the class file
or the package folder are located by the compiler. Any ideas as to what
might be going on?
THanks!
Peggy
Re: User Class Library [message #221905 is a reply to message #221845] Tue, 17 July 2007 10:03 Go to previous message
> file or the package folder are located by the compiler. Any ideas as to
> what might be going on?
It's hard to say what the problem is without more details. This is
something that is pretty common, so it is unlikely you are encountering
a bug.
Can you provide more details about the exact structure and build path
settings you have right now that are not working?
Eric
Previous Topic:Visual design with eclipse 3.3
Next Topic:mounted smb shares + projects
Current Time: Sat Apr 26 00:36:47 EDT 2025
Powered by FUDForum. Page generated in 0.05765 seconds
