Home » Modeling » GMF (Graphical Modeling Framework) » Setting properties into GMF
Setting properties into GMF [message #221594] Mon, 16 March 2009 18:12 Go to next message
Originally posted by: ralph.schreder.gmx.de
My task is to update a label of a node in my gmf diagram editor, like
the property view.
In my program I double click on a node. Than a dialog opens. Now I type
the values into this dialog.
After finishing the dialog I want to transfer the dialog parameters into
the gmf model.
How should I do this?
Ralph
Re: Setting properties into GMF [message #221624 is a reply to message #221594] Tue, 17 March 2009 06:47 Go to previous messageGo to next message
Hello Ralph,
Just get the model element from current selection and set property value
into it using EMF-generated api..
Alex Shatalin
Re: Setting properties into GMF [message #221721 is a reply to message #221624] Tue, 17 March 2009 10:50 Go to previous messageGo to next message
Thanks for your answer. But I think, this is not enough. My GMF diagram
model and figures have to be also updated. So I need a transaction.
- Ralph
Alex Shatalin schrieb:
> Hello Ralph,
> Alex Shatalin
Re: Setting properties into GMF [message #221902 is a reply to message #221721] Thu, 19 March 2009 07:43 Go to previous message
Hello Ralph,
You can subclass AbstractEMFOperation, implement doExecute method, run it
using OperationHistoryFactory.getOperationHistory().execute()
Alex Shatalin
Previous Topic:GMF load diagram file performance problem - eResolveProxy
Next Topic:How can I store the bounds information in the model features?
Current Time: Wed Apr 16 13:23:40 EDT 2025
Powered by FUDForum. Page generated in 0.03674 seconds
