problems view [message #221221] |
Tue, 05 August 2008 21:39 |
Originally posted by: noah.roberts.eng-software.com
Is there any way to get the problems view to just show me problems in
the project I just built? I'm trying to port things over from VS and
there's just a LOT of problems associated with that. It would be MUCH
easier if I could filter them down just a tad.
Re: problems view [message #221229 is a reply to message #221221] |
Tue, 05 August 2008 23:06 |
One way which I use quite a bit is - in view menu (click on little
triangle pointing down - on the right side of the view) enable
Show>Warnings on selection. After that, select a folder in Project
explorer. You gonna see only problems for this folder. You can also
"Configure contents" in the view menu to your liking.
Andrew
Re: problems view [message #221322 is a reply to message #221237] |
Wed, 06 August 2008 16:04 |
Michael Schulte wrote:
> That's what I would have suggested...
> (actually this is an eclipse.workbench issue, not eclipse.cdt)
> In all versions then (Europa and before):
> check the radio button: "On selected element and its children" (I always
> wonderer, why this is not the default option!)
Despite making the suggestion, I actually find this option a bit
inconvinient to use in our environment. What I really want is to see all
errors and warnings for a given subfolder all the time. Working in editor
selects just one file and hides away many errors I am interested in from
the view. There is an option to define working set for the folder, but I
have to switch to new different folder a way too often to define working
sets for each one of them. So I'd rather stick to the default being the
default in future.
Andrew
> Michael
>> Andrew
Re: problems view [message #221330 is a reply to message #221229] |
Wed, 06 August 2008 16:11 |
> Andrew
Heh, I'd never noticed that menu. I clicked everything but those
buttons because they look too much like windows boxes. Never thought to
expect a menu in one.
Thanks. This will give me some stuff to play with.
Re: problems view [message #221338 is a reply to message #221229] |
Wed, 06 August 2008 16:15 |
OK. That works but I only see the warnings. Is there a way to make this
exact behavior with errors as well?
Re: problems view [message #221344 is a reply to message #221338] |
Wed, 06 August 2008 16:18 |
>>> MUCH easier if I could filter them down just a tad.
Got it. I made a new filter and checked off "On any element in same
project" as well as checking off all severity boxes.
FUDForum. Page generated in 0.06049 seconds
