Home » Archived » GEF3D » Compiler Error
Compiler Error [message #1801] Wed, 18 March 2009 14:50 Go to next message
Madhu Samuel is currently offline Madhu SamuelFriend
Hello Jens,
I checked out the source from svn from
svn://dev.eclipse.org/svnroot/technology/org.eclipse.gef3d.
It has a few compiler errors.
1. org.lwgl is not found. Where can I download this from?
2. The class PerformanceOrbitCameraAction not found in ActionBuilder.java
Madhu
Re: Compiler Error [message #1813 is a reply to message #1801] Thu, 19 March 2009 10:49 Go to previous messageGo to next message
Jens von Pilgrim is currently offline Jens von PilgrimFriend
Hi Madhu,
On 2009-03-18 15:50:58 +0100, madhu.samuel@in.bosch.com (Madhu Samuel) said:
LWJGL has to be installed separately. I have written an install
instruction in the Wiki:
http://wiki.eclipse.org/GEF3D_Installation
Uuups.. sorry. I fixed this one. I forgot to check in the package
containing this action. It is a simple performance test, orbiting
around the diagrams and measuring the fps. Simply update the graph
example (or remove the action from the ActionBuilder).
Cheers
Jens
Re: Compiler Error [message #1828 is a reply to message #1813] Fri, 20 March 2009 06:39 Go to previous message
Thanks. Now its working!
Re: Compiler Error [message #561059 is a reply to message #1801] Thu, 19 March 2009 10:49 Go to previous message
Hi Madhu,
Cheers
Jens
Re: Compiler Error [message #561107 is a reply to message #1813] Fri, 20 March 2009 06:39 Go to previous message
Previous Topic:Limitations
Next Topic:Limitations
Current Time: Sat Nov 09 03:19:34 GMT 2024
Powered by FUDForum. Page generated in 0.03102 seconds
