Re: really interesting [message #1795 is a reply to message #1789] |
Fri, 06 March 2009 18:13 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
On 2009-03-03 10:06:50 +0100, Gr9vy Guy <gr8vyguy@googlemail.com> said:
> i want to know how to create diagrams like this one.
> http://www.fernuni-hagen.de/se/personen/pilgrim/gef3d/fig/sc reenshots/large/CombinationOf2DAnd3D01.jpg
do
> you have some documents or examples about it?
The screenshot shows a tool I've created for an article, see
"Constructing and Visualizing Transformation Chains" at
http://www.eclipse.org/gef3d/website/docs/index.php
If you want to create diagrams like that, the multi-editor example may
be a good starting point. I have described in my blog how to activate
the examples (and I really should write some more official
documentation about that...):
http://jevopisdeveloperblog.blogspot.com/2009/01/gef3d-commi tted-into-svn.html
The screenshot actually shows three UML diagrams (displayed using a
"3d-fied" version of TOPCASED UML), an ER diagram (created with a
quick-and-dirty GEF editor with about 15 classes) and three
trace-models. The latter are the red and green line between the planes.
So, in order to get something like this, you have to
1) 3D-fy your 2D GEF diagram editors (this is briefly explained in the
articles on the documentation page).
2) Create a 3D diagram editor for the inter-model-connections. The
"diagram" plane of the inter-model connections is invisible and it only
servers as a container.
3) If your connected elements on the planes are not aware of the
inter-model (or inter-diagram) connections, you may have a look at the
ConnectedElement-Pattern, described in the articles and found in
package o.e.gef3d.ext
If you have any problems, don't hesitate to post a message here---we
are well aware of the lack of documentation, and we are working on it
(but unfortunately our resources are limited).
Cheers
Jens
Re: really interesting [message #561013 is a reply to message #1789] |
do
Cheers
Jens
FUDForum. Page generated in 0.02977 seconds
