Home » Eclipse Projects » Eclipse Platform » Clean option in M8 works funny..
Clean option in M8 works funny.. [message #218589] Tue, 30 March 2004 20:33 Go to next message
Kevin Duffey is currently offline Kevin DuffeyFriend
Why is it when I am within a project, such as selected on a java file, and I
go to the Project -> Clean option, the only thing selected is Clean All. I
do not want to rebuild every project in the workspace. I only want to
rebuild the project that I am working with. And the build project set option
NEVER has anything in it, but in the New and Noteworty areas, it shows that
there is items working there...??
Re: Clean option in M8 works funny.. [message #218627 is a reply to message #218589] Tue, 30 March 2004 21:29 Go to previous message
Darin Swanson is currently offline Darin SwansonFriend
The way I can reproduce your problem is if the Java editor has focus. Core
should be able to resolve the project from the active Java editor.
I logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=56826
If you set the focus to the Package explorer, Clean enables as expected.
Darins
"spiderman" <supreme_java_guru_1@yahoo.com> wrote in message
news:c4cl9k$lue$1@eclipse.org...
I
option
that
Previous Topic:Getting content of a XML file
Next Topic:Eclispe 3.0M8 - Plugin - UI ActionSet
Current Time: Thu Aug 29 12:39:28 GMT 2024
Powered by FUDForum. Page generated in 0.02894 seconds
