Re: containers editparts - example-tutorial needed [message #218708 is a reply to message #218543] |
Wed, 28 June 2006 08:46 |
Sebastián Gurin Messages: 43 Registered: July 2009 |
Member |
Please ignore this message. I had an stupid error (bad reimplementation of EditPart.deactivate()).
Like always, gef was doing the right thing. My apologies.
On Mon, 26 Jun 2006 17:39:14 +0200
Sebastian Gurin <sgurin@montevideo.com.uy> wrote:
> Hi! Well, I'll try to explain my problem in my poor english, so please be patient ;-)
> I'm trying to implement a simple container for my gef editor. I have read the GEF-FAQ
> and done what it says. Also I have looked the logic example source code, but when
> moving a widget from a container to another an error occurs. Supose the edit part of
> the container is called ContainerEditPart. Here is what i'm doing:
> 1) install CONTAINER and LAYOUT policies in ContainerEditPart.
> 2) implement getModelChildren() in ContainerEditPart
> 3) in the CONTAINER edit policy (extends ContainerEditPolicy), getOrphanChildrenCommand()
> is responsably for returning a command that remove the element of the old parent
> 4) in the LAYOUT editPolicy (extends XYLayoutEditPolicy), getAddCommand() is responsably
> for returning a command that adds the element to the new parent
> 5) these both returned commands modify the model correctly and fire propertyChange events
> to corresponding editparts.
> 6) In editpart's propertyChange() method I do refreshChildren(). it's sufficient with
> this or I have to do something else here?
> The error manifestation: I think refreshChildren() creates new editparts but isn't
> erasing the edit parts corresponding to the elements in the old parent. Still more:
> When I try to visually manipulate the added element with the mouse, but it seems that
> it is accessing to the old edit part and not the new one.
> Well, I don't hope you understand me... but I do hope you correct the steps bellow
> for implementing the container. Also It would be very nice if you point me to a very
> simple example that implements containers (not logic-example, please) or a tutorial.
> Thanks very much!
> Sebastian Gurin
FUDForum. Page generated in 0.02854 seconds
