Unable to open documents through sun.applet.AppletViewer in eclipse-Request help [message #218212] |
Wed, 02 November 2005 11:27 |
Originally posted by: gr.sandeep.gmail.com
I am launching an applet from eclipse through Run -> Java Applet
configuration using the default AppletViewer which is
sun.applet.AppletViewer. In the applet, there is a piece of code which
opens a document (excel, xml etc) which is as below.
myApplet.getAppletContext().showDocument(url, "_blank");
Now, though the url is correct and points to a valid document, the applet
viewer doesn't show up the document.
When I launch the same applet through Internet Explorer, the same scenario
works fine and the documents are opened.
Kindly suggest why is the behaviour is so. Can appletviewer open doucments
as per the above line of code? If so, what am I doing wrong or missing?
Any workarounds?
Sandeep
FUDForum. Page generated in 0.03454 seconds
