Home » Archived » XML Schema Definition (XSD) » org.apache.xml.serialize.OutputFormat
org.apache.xml.serialize.OutputFormat [message #21132] Sun, 04 May 2003 18:44 Go to next message
Originally posted by: paechoi.earthlink.net
In the org.eclipse.xsd.util.XSDResourceImpl class, I see the
doSerialize() method that handles the output format for the
serializer.
Is there a way we can create the instance of
org.apache.xml.serialize.OutputFormat and pass it into the
serializer? If not, can we add a method that does for this
need? Something like:
public static void doSerialize(OutputStream outputStream, OutputFormat
outputFormat, Element element) throws IOException
In this way the user can have more flexibility as well as provide
an alternative way to access the xml declaration, <?xml ... ?>.
Thank you.
Pae
Re: org.apache.xml.serialize.OutputFormat [message #21230 is a reply to message #21132] Mon, 05 May 2003 06:58 Go to previous messageGo to next message
--------------21B9A48EFD42661211AB8FDB
Content-Type: text/plain; charset=us-ascii
Pae,
The latest driver has this overloaded version to make the encoding easy to
specify:
Element element, String encoding) throws IOException
OutputFormat outputFormat = new
OutputFormat(element.getOwnerDocument());
outputFormat.setLineWidth(80);
outputFormat.setIndenting(true);
outputFormat.setIndent(4);
outputFormat.setPreserveSpace(false);
outputFormat.setEncoding(encoding);
XMLSerializer serializer = new XMLSerializer(outputStream,
outputFormat);
serializer.serialize(element);
It seems to me that if you already have an output format, you may as well
use an XMLSerializer directly...
> serializer.
> Thank you.
> Pae
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Pae,
<p>The latest driver has this overloaded version to make the encoding easy
to specify:
<blockquote>&nbsp; public static void doSerialize(OutputStream outputStream,
<br>&nbsp; {
<br>&nbsp;&nbsp;&nbsp; OutputFormat outputFormat = new OutputFormat(element.getOwnerDocument());
<br>&nbsp;&nbsp;&nbsp; outputFormat.setLineWidth(80);
<br>&nbsp;&nbsp;&nbsp; outputFormat.setIndenting(true);
<br>&nbsp;&nbsp;&nbsp; outputFormat.setIndent(4);
<br>&nbsp;&nbsp;&nbsp; outputFormat.setPreserveSpace(false);
<br>&nbsp;&nbsp;&nbsp; outputFormat.setEncoding(encoding);
<br>&nbsp;&nbsp;&nbsp; XMLSerializer serializer = new XMLSerializer(outputStream,
outputFormat);
<br>&nbsp;&nbsp;&nbsp; serializer.serialize(element);
<br>&nbsp; }</blockquote>
<br>&nbsp;
<p>Pae Choi wrote:
<blockquote TYPE=CITE>In the org.eclipse.xsd.util.XSDResourceImpl class,
I see the
<br>doSerialize() method that handles the output format for the
<br>serializer.
<p>Is there a way we can create the instance of
<br>org.apache.xml.serialize.OutputFormat and pass it into the
<br>serializer? If not, can we add a method that does for this
<br>need? Something like:
<p>public static void doSerialize(OutputStream outputStream, OutputFormat
<br>outputFormat, Element element) throws IOException
<p>In this way the user can have more flexibility as well as provide
<br>an alternative way to access the xml declaration, &lt;?xml ... ?>.
<p>Thank you.
<p>Regards,
<p>Pae</blockquote>
</html>
--------------21B9A48EFD42661211AB8FDB--
Re: org.apache.xml.serialize.OutputFormat [message #21268 is a reply to message #21230] Mon, 05 May 2003 07:49 Go to previous message
------=_NextPart_000_005F_01C312DA.E0030290
charset="iso-8859-1"
Ed,
I know I am not going and am not expecting to get everything I ask. :-)
Pae
"Ed Merks" <merks@ca.ibm.com> wrote in message =
news:3EB643DD.C173543A@ca.ibm.com...
Pae,=20
The latest driver has this overloaded version to make the encoding =
easy to specify:=20
public static void doSerialize(OutputStream outputStream, Element =
element, String encoding) throws IOException=20
{=20
OutputFormat outputFormat =3D new =
OutputFormat(element.getOwnerDocument());=20
outputFormat.setLineWidth(80);=20
outputFormat.setIndenting(true);=20
outputFormat.setIndent(4);=20
outputFormat.setPreserveSpace(false);=20
outputFormat.setEncoding(encoding);=20
XMLSerializer serializer =3D new XMLSerializer(outputStream, =
outputFormat);=20
serializer.serialize(element);=20
It seems to me that if you already have an output format, you may as =
well use an XMLSerializer directly...=20
=20
Pae Choi wrote:=20
In the org.eclipse.xsd.util.XSDResourceImpl class, I see the=20
doSerialize() method that handles the output format for the=20
serializer.=20
Is there a way we can create the instance of=20
org.apache.xml.serialize.OutputFormat and pass it into the=20
serializer? If not, can we add a method that does for this=20
need? Something like:=20
public static void doSerialize(OutputStream outputStream, =
OutputFormat=20
outputFormat, Element element) throws IOException=20
In this way the user can have more flexibility as well as provide=20
an alternative way to access the xml declaration, <?xml ... ?>.=20
Thank you.=20
Regards,=20
Pae
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2600.0" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT size=3D2>Ed,</FONT></DIV>
<DIV><FONT size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT size=3D2>I know I am not going and am not expecting to get =
everything I=20
ask. :-)</FONT></DIV>
<DIV><FONT size=3D2>Regards,</FONT></DIV>
<DIV><FONT size=3D2>Pae</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Ed Merks" &lt;<A =
href=3D"mailto:merks@ca.ibm.com">merks@ca.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:3EB643DD.C173543A@ca.ibm.com">news:3EB643DD.C173543A@ca.ibm.=
com</A>...</DIV>Pae,=20
<P>The latest driver has this overloaded version to make the encoding =
easy to=20
specify:=20
<BLOCKQUOTE>&nbsp; public static void doSerialize(OutputStream =
outputStream,=20
Element element, String encoding) throws IOException <BR>&nbsp; {=20
<BR>&nbsp;&nbsp;&nbsp; OutputFormat outputFormat =3D new=20
OutputFormat(element.getOwnerDocument()); <BR>&nbsp;&nbsp;&nbsp;=20
outputFormat.setLineWidth(80); <BR>&nbsp;&nbsp;&nbsp;=20
outputFormat.setIndenting(true); <BR>&nbsp;&nbsp;&nbsp;=20
outputFormat.setIndent(4); <BR>&nbsp;&nbsp;&nbsp;=20
outputFormat.setPreserveSpace(false); <BR>&nbsp;&nbsp;&nbsp;=20
outputFormat.setEncoding(encoding); <BR>&nbsp;&nbsp;&nbsp; =
XMLSerializer=20
serializer =3D new XMLSerializer(outputStream, outputFormat);=20
<BR>&nbsp;&nbsp;&nbsp; serializer.serialize(element); <BR>&nbsp;=20
}</BLOCKQUOTE>It seems to me that if you already have an output =
format, you=20
may as well use an XMLSerializer directly... <BR>&nbsp;=20
<P>Pae Choi wrote:=20
<BLOCKQUOTE TYPE=3D"CITE">In the org.eclipse.xsd.util.XSDResourceImpl =
class, I=20
see the <BR>doSerialize() method that handles the output format for =
the=20
<BR>serializer.=20
<P>Is there a way we can create the instance of=20
<BR>org.apache.xml.serialize.OutputFormat and pass it into the=20
<BR>serializer? If not, can we add a method that does for this =
<BR>need?=20
Something like:=20
<P>public static void doSerialize(OutputStream outputStream, =
OutputFormat=20
<BR>outputFormat, Element element) throws IOException=20
<P>In this way the user can have more flexibility as well as provide =
<BR>an=20
alternative way to access the xml declaration, &lt;?xml ... ?&gt;.=20
<P>Thank you.=20
<P>Regards,=20
<P>Pae</P></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_005F_01C312DA.E0030290--
Re: org.apache.xml.serialize.OutputFormat [message #570154 is a reply to message #21132] Mon, 05 May 2003 06:58 Go to previous message
Pae,
specify:
outputFormat);
> serializer.
> Thank you.
> Pae
<html>
Pae,
to specify:
<br>&nbsp; {
outputFormat);
<br>&nbsp;
I see the
<br>serializer.
<p>Thank you.
<p>Regards,
<p>Pae</blockquote>
</html>
Re: org.apache.xml.serialize.OutputFormat [message #570351 is a reply to message #21230] Mon, 05 May 2003 07:49 Go to previous message
Ed,
Pae
Pae,=20
easy to specify:=20
{=20
outputFormat);=20
=20
Pae Choi wrote:=20
serializer.=20
OutputFormat=20
Thank you.=20
Regards,=20
Pae
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
everything I=20
easy to=20
specify:=20
outputStream,=20
XMLSerializer=20
format, you=20
class, I=20
the=20
<BR>serializer.=20
<BR>need?=20
Something like:=20
OutputFormat=20
<BR>an=20
<P>Thank you.=20
<P>Regards,=20
Previous Topic:A Test with http://www.w3.org/2001/XMLSchema.xsd
Next Topic:A Diagnostic Message for the Valid Schema
Current Time: Thu Oct 30 16:34:59 EDT 2025
Powered by FUDForum. Page generated in 0.10623 seconds
