Home » Eclipse Projects » Buckminster dev » Other actors proposal
Other actors proposal [message #21118] Thu, 03 July 2008 02:00 Go to next message
Hi everyone,
Buckminster really is a great tool and it's easy to use with eclipse and
java. Buckminster is a good tool to drive a team to continous
integration so I decided to use it as well with our C++ projects. I
managed to get the whole C++ pipe running but the learning curve is
really steep. Here are the steps to accomplish :
-1- Make the buckminster.cspec (detail the dependencies, the actions)
-2- Use prerequisites in the actions to refer to abstract paths of other
components
-3- Use ant to retrieve archives, uncompress them, set a lot of
environnement variables, call the compiler (which is also a component).
-4- Write the makefile ( or compilation instructions )
Ant is a great tool but it's really hard to explain to someone coming
from C++. It's not an easy langage to learn and a lot of action are hard
to do (branching for instance) or impossible to do (loops). Moreover
debugging the execution is a pain in the ass because of the many
langages involved ( buckminster, ant, makefile )
What do you think of a "shell" actor that would just execute a shell
script with the ability to set environement variables as prerequesites ?
To my mind, this would greatly simplify the pipe, the maintenance and
would ease the adoption - learning buckminster is hard but having to
learn buckminster + ant is very hard to my team mates.
It could be fantastic if one could just call the compiler in a
buckminster's action, building the command line within the cspec and
setting the environnement variables in the cspec : less langages, less
code, less debugging, happier developers : )
Tell me what you think about that,
Guillaume
Re: Other actors proposal [message #21141 is a reply to message #21118] Thu, 03 July 2008 02:20 Go to previous messageGo to next message
Hi Guillaume,
I've been thinking about a shell actor too. The primary reason why it's
not implemented yet is probably that we, as you say, have been too Java
centric. Java developers use ant and call shell from there.
I'm all for a shell actor. If you would like to have a go at it and
submit a patch, we would be very interested. I promise to be responsive
if you have questions concerning the implementation.
The C++ domain that you're in sounds very interesting. People are asking
for it but so far we haven't had the time or resources to really dive
into it. If you can find some time to share your experience in a bit
more detail (examples and such), I think that would be very valuable to
Buckminster.
Kind Regards,
Thomas Hallgren
Guillaume CHATELET wrote:
> Hi everyone,
> components
> Best regards,
> Guillaume
Re: Other actors proposal [message #21512 is a reply to message #21141] Fri, 18 July 2008 09:18 Go to previous messageGo to next message
Hi Thomas,
I really wish I had more time to tackle this subject but for now I'm completely drowned under tons of tasks.
Nevertheless I'll try to group here a few ideas that I have.
As I said in my previous post, the work flow for building a C++ project is as follow :
+ Create Spec components to describe dependencies
+ Specify actions ( ant actor for the moment ) to :
=> retrieving files from urls
=> retrieving files from archives pointed by url
=> executing commands with specific environment variables (eg. calling the compiler with paths to libraries)
+ Write ant files
+ Create the script to compile the code ( Makefile or Boost Jamfile or SCons file )
Those steps makes debugging a real puzzle, plus it forces us to rewrite the same ant functions in barely all our components.
We factorized this code by creating scripts in a component named *ant_base_scripts* but it's not really convenient : we have to include those scripts in the prerequisites of buckminster's actions, add an alias to it. Ant then "import" them in our ant scripts to actually perform the actions for the component.
-- Zapping ant
The basic idea is to suppress the ant step because :
+ it's quite hard to learn for non java developers
+ it's quite hard to write ( to my mind XML is not a good language to express code )
+ it's even harder to debug
From this point of view Ant is cluttering and cumbersome.
-- Suggestions
+ adding an "executor" action type to actually execute programs ( batch scripts, compilers, tests, etc... ) possibly programs defined in other component. This action can execute the program with a set of environment variables defined in the CSpec (possibly by referring other components).
+ adding a mean to materialize zipped resources under a component from Buckminster ( no ant call with get, unzip, copy )
eg: I want to retrieve Boost 1.35 ( http://www.boost.org/ )
I'd like to write a Spec component that is able to retrieve this archive http://downloads.sourceforge.net/boost/boost_1_35_0.tar.bz2, uncompress it under it's root ( maybe I want to filter the content of the archive or maybe I want it to be uncompressed under a particular directory ). These files are then accessed through artifacts or groups.
-- What's next
Sure, those few lines are rather insufficient to express the needs but it's a first step.
Thomas, I'm planning to open a wiki ( Google Sites ) to store examples, scenarios, grammars and keep track of comments and suggestions.
I think it's more convenient than the newsgroups to store images, code snippet and other things.
If you agree, I'll try to open it quickly to start the project.
Guillaume
Thomas Hallgren wrote:
> Hi Guillaume,
> Buckminster.
> Kind Regards,
> Thomas Hallgren
>> Hi everyone,
>> and java. Buckminster is a good tool to drive a team to continous
>> other components
>> hard to do (branching for instance) or impossible to do (loops).
>> Moreover debugging the execution is a pain in the ass because of the
>> many langages involved ( buckminster, ant, makefile )
>> Best regards,
>> Guillaume
Re: Other actors proposal [message #21538 is a reply to message #21141] Fri, 18 July 2008 09:19 Go to previous messageGo to next message
Hi Thomas,
+ Write ant files
-- Zapping ant
-- Suggestions
-- What's next
Guillaume
> Hi Guillaume,
> Buckminster.
> Kind Regards,
> Thomas Hallgren
>> Hi everyone,
>> other components
>> Best regards,
>> Guillaume
Re: Other actors proposal [message #21580 is a reply to message #21512] Fri, 18 July 2008 09:41 Go to previous messageGo to next message
Hi Guillaume,
I think you have very good suggestions. I can understand if you feel
that time is short and you don't have time to implement the "executor"
action right now.
Regarding the wiki, feel free to add things to wiki.eclipse.org. It's
open for anyone who has an Bugzilla account.
We like to use categories to get structure so you can tag the articles
with [[Category:Buckminster]] and [[Category:Buckminster Examples]].
Thomas Hallgren
> Hi Thomas,
> is as follow :
> + Write ant files
> SCons file )
> -- Zapping ant
> express code )
> -- Suggestions
> -- What's next
> it's a first step.
> Guillaume
>> Hi Guillaume,
>> it's not implemented yet is probably that we, as you say, have been
>> too Java centric. Java developers use ant and call shell from there.
>> responsive if you have questions concerning the implementation.
>> asking for it but so far we haven't had the time or resources to
>> really dive into it. If you can find some time to share your
>> experience in a bit more detail (examples and such), I think that
>> would be very valuable to Buckminster.
>> Kind Regards,
>> Thomas Hallgren
>>> Hi everyone,
>>> other components
>>> less code, less debugging, happier developers : )
>>> Best regards,
>>> Guillaume
Re: Other actors proposal [message #21626 is a reply to message #21580] Sat, 19 July 2008 08:30 Go to previous messageGo to next message
Hi Thomas,
As you suggested, I started some pages on the wiki :
http://wiki.eclipse.org/Non_Java_projects_Proposal
It's still under construction for the moment. I also placed a link to
this page at http://wiki.eclipse.org/Helping_Out_(Buckminster) so other
people could contribute.
At the same time I downloaded Buckminster sources and had a look to the
Ant actor. I started a plugin : org.eclipse.buckminster.executor but as
I was looking at org.eclipse.buckminster.ant plugin I noticed that a
"Build Script" extension point was proposed. Do you think I should
extend org.eclipse.buckminster.ant or create another plugin ?
Have you got more technical documentation about Buckminster so I could
dive into the code more easily ?
Guillaume
Thomas Hallgren a écrit :
> Hi Guillaume,
> action right now.
> Thomas Hallgren
>> Hi Thomas,
>> + Write ant files
>> SCons file )
>> -- Zapping ant
>> express code )
>> -- Suggestions
>> other components).
>> -- What's next
>> it's a first step.
>> Regards,
>> Guillaume
>>> Hi Guillaume,
>>> Kind Regards,
>>> Thomas Hallgren
>>>> Hi everyone,
>>>> other components
>>>> coming from C++. It's not an easy langage to learn and a lot of
>>>> action are hard to do (branching for instance) or impossible to do
>>>> (loops). Moreover debugging the execution is a pain in the ass
>>>> because of the many langages involved ( buckminster, ant, makefile )
>>>> prerequesites ?
>>>> and would ease the adoption - learning buckminster is hard but
>>>> having to learn buckminster + ant is very hard to my team mates.
>>>> Best regards,
>>>> Guillaume
Re: Other actors proposal [message #21671 is a reply to message #21626] Sat, 19 July 2008 11:35 Go to previous message
Hi Guillaume,
> Hi Thomas,
Looks very good.
> other people could contribute.
Good idea.
> the Ant actor. I started a plugin : org.eclipse.buckminster.executor
> but as I was looking at org.eclipse.buckminster.ant plugin I noticed
> that a "Build Script" extension point was proposed. Do you think I
> should extend org.eclipse.buckminster.ant or create another plugin ?
I think it's better to create a new plug-in so that no unnecessary
dependency is to ant is implied.
No sorry. All we got at this time is on the wiki.
Thomas Hallgren
> Guillaume
>> Hi Guillaume,
>> "executor" action right now.
>> articles with [[Category:Buckminster]] and [[Category:Buckminster
>> Examples]].
>> Regards,
>> Thomas Hallgren
>>> Hi Thomas,
>>> + Write ant files
>>> or SCons file )
>>> -- Zapping ant
>>> to express code )
>>> -- Suggestions
>>> other components).
>>> -- What's next
>>> suggestions.
>>> Regards,
>>> Guillaume
>>>> Hi Guillaume,
>>>> Kind Regards,
>>>> Thomas Hallgren
>>>>> Hi everyone,
>>>>> eclipse and java. Buckminster is a good tool to drive a team to
>>>>> continous integration so I decided to use it as well with our C++
>>>>> projects. I managed to get the whole C++ pipe running but the
>>>>> learning curve is really steep. Here are the steps to accomplish :
>>>>> other components
>>>>> component).
>>>>> shell script with the ability to set environement variables as
>>>>> prerequesites ?
>>>>> and setting the environnement variables in the cspec : less
>>>>> langages, less code, less debugging, happier developers : )
>>>>> Best regards,
>>>>> Guillaume
Previous Topic:Automated build / test stuff for Buckminster
Next Topic:[buckminster-dev] Hello XML World Example error
Current Time: Sat Oct 18 03:02:09 EDT 2025
Powered by FUDForum. Page generated in 0.04137 seconds
