Home » Eclipse Projects » Eclipse Platform » Organize imports ignoring class
Organize imports ignoring class [message #216785] Sat, 27 March 2004 19:01 Go to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
I have a class called pj2Plugin. When i call a method on this class like so
pj2Plugin.log("sdsda");
it will be highlighted in red because its not imported. But if I try to
do a ctrl-shift-O, the class will NOT be imported. I have to add it
manually. And under certain conditions it will even remove the thing.
Any idea why this is? does it not like classes that start with
lowercase letters?
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Organize imports ignoring class [message #216815 is a reply to message #216785] Sat, 27 March 2004 23:38 Go to previous message
I have seen this in the past several builds as well. I figured it was a bug
but it doesn't occur all the time. The time I have seen this is when I add a
new class, then go to use that new class in another class. It is on the
classpath, and Eclipse IDE has already compiled it as I see it in the output
folder as well. So it's not a matter of not being part of the classpath or
not yet compiled. It seems odd that this happens, and like you said, even
after manually typing it, I still see the red line (sometimes), and if I
organize again, my import is gone.
"CL [dnoyeb] Gilbert" <Lamont_Gilbert@rigidsoftware.com> wrote in message
news:c454bg$dmr$1@eclipse.org...
so
> lowercase letters?
> Respectfully,
> CL Gilbert
Previous Topic:Keep next/previous part dialog open
Next Topic:Idea for editor, before entring it...
Current Time: Fri Nov 07 05:35:49 EST 2025
Powered by FUDForum. Page generated in 0.03477 seconds
