Home » Archived » Test and Performance Tools Platform (TPTP) » JVM crashes while running TPTP 4.0 on Eclipse 3.1RC3 (JRE 1.4.2)
JVM crashes while running TPTP 4.0 on Eclipse 3.1RC3 (JRE 1.4.2) [message #21009] |
Wed, 29 June 2005 12:59  |
Originally posted by: kholodov.ncbi.nlm.nih.gov
I'm trying to profile an application (Execution Time only) and I get a
VM crash. The operating system is Windows 2000 Professional, JRE 1.4.2,
Eclipse 3.1RC3, emf-sdo-xsd-SDK-I200506230200,
tptp.runtime-TPTP-4.0.0-200506280100
tptpdc.win_ia32-TPTP-4.0.0-200506280100
The TPTP 3.3 version works fine, I tried to test the new functionality
in 4.0.
Thanks, Mike
The VM crash log is below:
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : EXCEPTION_ACCESS_VIOLATION (0xc0000005) occurred at
PC=0x77FCC3A0
Function=RtlAllocateHeap+0x2B1
Library=C:\WINNT\system32\ntdll.dll
Current Java thread:
at java.lang.Object.wait(Native Method)
- waiting on <0x100a01a0> (a java.lang.ref.Reference$Lock)
at java.lang.Object.wait(Unknown Source)
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0x100a01a0> (a java.lang.ref.Reference$Lock)
Dynamic libraries:
0x00400000 - 0x00406000 C:\Program Files\Java\j2re1.4.2_04\bin\java.exe
0x77F80000 - 0x77FFD000 C:\WINNT\system32\ntdll.dll
0x7C2D0000 - 0x7C332000 C:\WINNT\system32\ADVAPI32.dll
0x7C570000 - 0x7C623000 C:\WINNT\system32\KERNEL32.DLL
0x77D30000 - 0x77DA1000 C:\WINNT\system32\RPCRT4.DLL
0x78000000 - 0x78045000 C:\WINNT\system32\MSVCRT.dll
0x08000000 - 0x08138000 C:\Program
Files\Java\j2re1.4.2_04\bin\client\jvm.dll
0x77E10000 - 0x77E6F000 C:\WINNT\system32\USER32.dll
0x77F40000 - 0x77F7B000 C:\WINNT\system32\GDI32.dll
0x77570000 - 0x775A0000 C:\WINNT\system32\WINMM.dll
0x75E60000 - 0x75E7A000 C:\WINNT\system32\IMM32.DLL
0x10000000 - 0x10007000 C:\Program Files\Java\j2re1.4.2_04\bin\hpi.dll
0x007C0000 - 0x007CE000 C:\Program Files\Java\j2re1.4.2_04\bin\verify.dll
0x007D0000 - 0x007E9000 C:\Program Files\Java\j2re1.4.2_04\bin\java.dll
0x007F0000 - 0x007FD000 C:\Program Files\Java\j2re1.4.2_04\bin\zip.dll
0x18170000 - 0x18205000 E:\Apps\raserver\bin\piAgent.dll
0x75030000 - 0x75044000 C:\WINNT\system32\WS2_32.dll
0x75020000 - 0x75028000 C:\WINNT\system32\WS2HELP.DLL
0x18210000 - 0x1821B000 E:\Apps\raserver\bin\hcclco.dll
0x18220000 - 0x18228000 E:\Apps\raserver\bin\hccldt.dll
0x18230000 - 0x18241000 E:\Apps\raserver\bin\hcclsm.dll
0x18250000 - 0x1825D000 E:\Apps\raserver\bin\hccls.dll
0x18260000 - 0x1826B000 E:\Apps\raserver\bin\hcbnd.dll
0x782C0000 - 0x782CC000 C:\WINNT\System32\rnr20.dll
0x77980000 - 0x779A4000 C:\WINNT\system32\DNSAPI.DLL
0x75050000 - 0x75058000 C:\WINNT\system32\WSOCK32.DLL
0x77340000 - 0x77353000 C:\WINNT\system32\iphlpapi.dll
0x77520000 - 0x77525000 C:\WINNT\system32\ICMP.DLL
0x77320000 - 0x77337000 C:\WINNT\system32\MPRAPI.DLL
0x75150000 - 0x7515F000 C:\WINNT\system32\SAMLIB.DLL
0x75170000 - 0x751BF000 C:\WINNT\system32\NETAPI32.DLL
0x7C340000 - 0x7C34F000 C:\WINNT\system32\Secur32.dll
0x77BF0000 - 0x77C01000 C:\WINNT\system32\NTDSAPI.dll
0x77950000 - 0x7797A000 C:\WINNT\system32\WLDAP32.DLL
0x751C0000 - 0x751C6000 C:\WINNT\system32\NETRAP.dll
0x77A50000 - 0x77B3F000 C:\WINNT\system32\OLE32.DLL
0x779B0000 - 0x77A4B000 C:\WINNT\system32\OLEAUT32.DLL
0x773B0000 - 0x773DF000 C:\WINNT\system32\ACTIVEDS.DLL
0x77380000 - 0x773A3000 C:\WINNT\system32\ADSLDPC.DLL
0x77830000 - 0x7783E000 C:\WINNT\system32\RTUTILS.DLL
0x77880000 - 0x7790E000 C:\WINNT\system32\SETUPAPI.DLL
0x7C0F0000 - 0x7C151000 C:\WINNT\system32\USERENV.DLL
0x774E0000 - 0x77513000 C:\WINNT\system32\RASAPI32.DLL
0x774C0000 - 0x774D1000 C:\WINNT\system32\RASMAN.DLL
0x77530000 - 0x77552000 C:\WINNT\system32\TAPI32.DLL
0x71710000 - 0x71794000 C:\WINNT\system32\COMCTL32.DLL
0x70A70000 - 0x70AD6000 C:\WINNT\system32\SHLWAPI.DLL
0x77360000 - 0x77379000 C:\WINNT\system32\DHCPCSVC.DLL
0x777E0000 - 0x777E8000 C:\WINNT\System32\winrnr.dll
0x777F0000 - 0x777F5000 C:\WINNT\system32\rasadhlp.dll
0x77920000 - 0x77943000 C:\WINNT\system32\imagehlp.dll
0x72A00000 - 0x72A2D000 C:\WINNT\system32\DBGHELP.dll
0x690A0000 - 0x690AB000 C:\WINNT\system32\PSAPI.DLL
Heap at VM Abort:
Heap
def new generation total 576K, used 576K [0x10010000, 0x100b0000,
0x104f0000)
eden space 512K, 100% used [0x10010000, 0x10090000, 0x10090000)
from space 64K, 100% used [0x100a0000, 0x100b0000, 0x100b0000)
to space 64K, 0% used [0x10090000, 0x10090000, 0x100a0000)
tenured generation total 1408K, used 169K [0x104f0000, 0x10650000,
0x14010000)
the space 1408K, 12% used [0x104f0000, 0x1051a610, 0x1051a800,
0x10650000)
compacting perm gen total 4096K, used 1617K [0x14010000, 0x14410000,
0x18010000)
the space 4096K, 39% used [0x14010000, 0x141a46f8, 0x141a4800,
0x14410000)
Local Time = Wed Jun 29 12:49:10 2005
Elapsed Time = 17
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_04-b05 mixed mode)
# An error report file has been saved as hs_err_pid2060.log.
# Please refer to the file for further information.
Another exception has been detected while we were handling last error.
Dumping information about last error:
ERROR REPORT FILE = hs_err_pid2060.log
PC = 0x77fcc3a0
SIGNAL = -1073741819
FUNCTION NAME = RtlAllocateHeap
OFFSET = 0x2B1
LIBRARY NAME = C:\WINNT\system32\ntdll.dll
Please check ERROR REPORT FILE for further information, if there is any.
Good bye.
Re: JVM crashes while running TPTP 4.0 on Eclipse 3.1RC3 (JRE 1.4.2) [message #21036 is a reply to message #21009] |
Wed, 29 June 2005 15:09   |
Are you sure that you don't have the dll file of the 3.3 agent controller in
your system path?
Can you temporarily rename the piAgent.dll to piAgent.dll.old in the bin
directory of your agent controller 3.3 driver and then try and start the
agent controller of 4.0.
See if the problem is still reproducible. I suspect that an old dll file is
getting picked up.
I will forward your message to the developer that owns the JVMPI component
to see if he has anything to add.
"Michael Kholodov" <kholodov@ncbi.nlm.nih.gov> wrote in message
news:d9uk0l$uq$1@news.eclipse.org...
> I'm trying to profile an application (Execution Time only) and I get a VM
> The TPTP 3.3 version works fine, I tried to test the new functionality in
> 4.0.
> Thanks, Mike
> PC=0x77FCC3A0
> Dynamic libraries:
> Heap at VM Abort:
> Heap
> 0x104f0000)
> 0x14010000)
> 0x10650000)
> 0x18010000)
> 0x14410000)
> Elapsed Time = 17
> PC = 0x77fcc3a0
> OFFSET = 0x2B1
> Good bye.
Re: JVM crashes while running TPTP 4.0 on Eclipse 3.1RC3 (JRE 1.4.2) [message #21052 is a reply to message #21036] |
Wed, 29 June 2005 16:33  |
I did a search for piAgent.dll in all my hard drives, it didn't find
anything except the one from version 4.0 directory. Actually I have only
version 4.0 agent installed and it worked with TPTP 3.3 without any
problems. May be I installed something wrong? I just extracted EMF and
TPTP into my Eclipse directory, extracted the agent controller into a
different directory, ran the SetConfig.bat and ran raserver. Raserver
-version says it's 4.0.0.0.
Just checked TPTP 3.3 with EMF 2.1, Eclipse 3.1, RAServer 4.0 - worked fine.
-Mike
> your system path?
> getting picked up.
>>4.0.
>>Thanks, Mike
>>PC=0x77FCC3A0
>>Dynamic libraries:
>>Heap at VM Abort:
>>Heap
>>0x104f0000)
>>0x14010000)
>>0x10650000)
>>0x18010000)
>>0x14410000)
>>Elapsed Time = 17
>>PC = 0x77fcc3a0
>>OFFSET = 0x2B1
>>Good bye.
Current Time: Mon Oct 20 00:28:18 EDT 2025
Powered by FUDForum. Page generated in 0.05536 seconds
