Home » Language IDEs » C / C++ IDE (CDT) » application with static library segfaults
application with static library segfaults [message #216046] Wed, 14 May 2008 02:16 Go to next message
Reid Swanson is currently offline Reid SwansonFriend
I have 4 managed make projects: an executable and 3 static libraries.
Everything builds fine and when I run the application from the run dialog
within eclipse everything works ok. However, when I try to run the same
application from a terminal the program segfaults. Could somebody help me
figure out why the two executables are behaving differently?
I'm using Eclipse 3.3.2 Build id: M20080221-1800
not sure about the exact CDT version but I think it's 4.0.0
Running on Ubuntu linux 8.04 with gcc 4.2.3
Reid
Re: application with static library segfaults (solved) [message #216056 is a reply to message #216046] Wed, 14 May 2008 04:12 Go to previous message
Sorry really embarrassed but somehow the active build directory got
changed and I hadn't noticed.
Previous Topic:gdb gets suspended
Next Topic:IASTTranslationUnit and parsing PDOM
Current Time: Sat Nov 09 02:37:18 GMT 2024
Powered by FUDForum. Page generated in 0.02706 seconds
