| Format-Keys on Linux are not working [message #214635] |
Tue, 13 September 2005 08:23  |
Originally posted by: torsten.tkunkel.de
I've a strange problem. The shortkey for format code does not work
correctly, everytime I press Control-Shift-F (like on Windows) at the
cursors position a underlined F is displayed, when releasing the keys,
it dissapears.
I think the X-Server catches the keycombination, but Control-Shift-S for
organize imports works fine.
In order to get format code I've to hit escape and then press Control F
together.
The keymapping shows:
Category: Source
Command: Format
Key Sequence: Shift+Ctrl+F
When: Editing Java Source
and
Category: Source
Command: Format
Key Sequence: Esc Ctrl+F
I'm nearly shure the problem isn't eclipse, but I don't know where to
edit this behavior, so I hope someone has solved this already :)
Does anyone know something about this?
Greetings
Torsten
FUDForum. Page generated in 0.04258 seconds
