Home » Eclipse Projects » Eclipse Platform » how to determine path to plugin jar
how to determine path to plugin jar [message #214339] Mon, 22 March 2004 08:14 Go to next message
Originally posted by: nospamhoell.aeb.de
How can I programmatically determine path and name of the plugin jar file?
and, how it is possible to write from an plugin to the console output, or
what is the common way to write some output (writeln) from an plugIn to show
the user some "lined" information?
tia!
Re: how to determine path to plugin jar [message #214487 is a reply to message #214339] Mon, 22 March 2004 15:05 Go to previous message
plugin.getDescriptor().getInstallURL() will give you the installation
directory of your plugin so you should be able to locate your jar file
there.
Ciao, Michael.
Previous Topic:How to chang LaunchConfiguration inside LaunchConfigurationDelegate?
Next Topic:Eclipse 3.0 and accessibility
Current Time: Tue May 20 23:44:19 EDT 2025
Powered by FUDForum. Page generated in 0.06335 seconds
