Debug Issue [message #213762] |
Fri, 19 March 2004 22:33 |
Originally posted by: tjunker.email.uophx.edu
------=_NextPart_000_0064_01C40DBF.1762EBD0
Content-Type: text/plain;
charset="iso-8859-1"
I am using Eclipse 3.0.0 with tomcat-5.0.19. I can start and stop =
the server from within Eclipse and when I set breakpoint Eclipse =
switches to debug perspective and halts execution. The problem I am =
having is that it does not track the line in the source like WSAD 5.0. =20
=20
I that just the way it is or do I need an additional plugin?
TJ
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2734.1600" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV>Hi,</DIV>
<DIV> I am using Eclipse 3.0.0 with =
tomcat-5.0.19. I can=20
start and stop the server from within Eclipse and when I set breakpoint =
Eclipse=20
switches to debug perspective and halts execution. The problem I =
am having=20
</DIV>
<DIV> </DIV>
<DIV> I that just the way it is or do I need an =
additional=20
plugin?</DIV>
<DIV><BR>TJ</DIV></BODY></HTML>
------=_NextPart_000_0064_01C40DBF.1762EBD0--
Re: Debug Issue [message #213920 is a reply to message #213762] |
Sat, 20 March 2004 08:02 |
Please check your compiler preferences. For me it seems that your code is
not compiled that way. There is no difference between Eclipse and WSAD when
debugging.
Cu, Gunnar
Re: Debug Issue [message #214068 is a reply to message #213920] |
Sat, 20 March 2004 22:45 |
Thanks Gunnar,
I see debug tracking the source in simple java projects; however, when I
try to do the same thing with a struts application it does not track.
Still mystified.
TIM JUNKER
"Gunnar Wagenknecht" <g.wagenknecht@planet-wagenknecht.de> wrote in message
news:c3gthc$sp7$1@eclipse.org...
when
> debugging.
> Cu, Gunnar
FUDForum. Page generated in 0.03202 seconds
