HTTP 404 Not Found with Help Contents [message #20686] |
Sat, 29 January 2005 19:37 |
Originally posted by: plutz.it.rit.edu
When I select Help -> Help Contents, I get an HTTP 404 Not Found error.
This is
with a brand new installation of Eclipse 3.0.1. Happens even with my
firewall turned off and McAfee's On Access Scan turned off.
Any Pointers??? I have been all over the web with no success.
Pete
Re: HTTP 404 Not Found with Help Contents [message #27641 is a reply to message #20686] |
Wed, 16 February 2005 16:25 |
Originally posted by: Jwyatt1980.adelphia.net
> This is
> Pete
Pete,
Try this.
Open up Eclipse. Go to Window->Preferences->Help->Helpserver.
In the Hostname or IP address field enter: 127.0.0.1
This should fix your problem. It worked for me once, although I forget
the exact nature of the problem though.
John
Re: HTTP 404 Not Found with Help Contents [message #149942 is a reply to message #20686] |
Thu, 27 April 2006 00:36 |
Originally posted by: mchambers.nospam.objectmastery.com
> This is
> Pete
Peter,
Did you find a solution to this problem? I have the same symptom.
Mark Chambers
Re: HTTP 404 Not Found with Help Contents [message #150354 is a reply to message #149942] |
Sat, 29 April 2006 21:31 |
Originally posted by: dcurry.glic.com
I was having this problem at work, but not at home. Turns out the web
proxy at work was missing an entry in its configuration script (the
wpad.dat file) to tell the browser to make a direct connection to
"127.0.0.1". If you're using a web proxy, try going into IE's
Tools->Internet Options->Connections->LAN Settings and turning all the
proxy stuff off. Then see if Eclipse Help works.
--Dave
FUDForum. Page generated in 0.08933 seconds
