| 2 requests with 4 commands each. I loose 3 of the 8 [message #213208] |
Mon, 03 April 2006 18:30   |
Eclipse User  |
I have a box, with subBoxes. Both are placed in what I call Diagram, the
  equivalent of a Graph, and the boxes would be vertices.
When I delete a subBox, all subsequent subBoxes must be moved, and the
box resized. I use a CompoundCommand:
1 - DeleteCommand : remove subBox from box (this could be skiped)
2 - DeleteCommand : remove subBox from the Diagram
3 - MoveCommand: move the following subBox (could be multiple of this)
4 - MoveCommand: resizes the box
Now, when I select two subboxes, 2 requests are created with the same
structure above, however, this is what is executed
Req1
Req2
1 - MoveCommand: move the following subBox (could be multiple of this)
2 - MoveCommand: resizes the box
3 - DeleteCommand : remove subBox from the Diagram
So I lost 3 commands. Any tips on how to debug this or why is this
happening? I've tried a few things already, but I'm puzzled
Would it help if I provided more detailed description? It would be a bit
long.
thanks
| Re: 2 requests with 4 commands each. I loose 3 of the 8 [message #213218 is a reply to message #213208] |
Mon, 03 April 2006 19:49   |
Eclipse User  |
Ok, this is what I'm talking about. I have SubBoxComponentPolicy with
some code. Using the method bellow, I moved the code from
SubBoxComponentPolicy to BoxComponentPolicy
public Command getCommand(Request request) {
   CompoundCommand cmd = new CompoundCommand();
   if (request.getType().equals(REQ_DELETE)) {
     Box box = (Box) getHost().getParent().getModel();
     request.setType(REQ_DELETE_DEPENDANT);
     Map m = new HashMap();
     m.put("selectedElement", getHost().getModel());
     request.setExtendedData(m);
     cmd.add(getEditPart(box).getCommand(request));
   else if (request.getType().equals(REQ_DELETE_DEPENDANT)) {
     cmd.add (createDeleteCommand((GroupRequest)request));
   return cmd;
Anyone had previous experience with this?
thanks
FUDForum. Page generated in 0.05634 seconds
