eclipse/j2sdk installation on Red Hat 9 [message #212352] |
Wed, 17 March 2004 12:12  |
Originally posted by: equaglia.yahoo.com
Hi.
I've just installed eclipse and j2sdk1.4.2_04 on linux (Red Hat 9).
I got the following error trying to launch eclipse for the first time.
Does anyone know how to help me on that?
Eduardo Quaglia.
Problems during startup. Check the ¨.log¨ file in the ¨.metadata¨
directory of your workspace.
..log file:
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Mar 17, 2004 10:40:21.351
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.IllegalStateException: Unable to acquire application service
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:103)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
!SESSION
!ENTRY org.eclipse.core.launcher 4 0 Mar 17, 2004 11:56:42.294
!STACK
Re: eclipse/j2sdk installation on Red Hat 9 [message #212382 is a reply to message #212378] |
Wed, 17 March 2004 13:30  |
java (the right one) launches fine.
My $PATH is:
/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/usr/eclipse:/us r/eclipse/plugins:/usr/j2sdk/j2sdk1.4.2_04/bin:/usr/j2sdk/j2 sdk1.4.2_04/jre/bin:/usr/local/amzi/amzi_6-2-13/bin:/home/eq uaglia/bin:/usr/eclipse:/usr/eclipse/plugins:/usr/j2sdk/j2sd k1.4.2_04/bin:/usr/j2sdk/j2sdk1.4.2_04/jre/bin:
I thought it could be a problem on finding the eclipse classes, so I
also added /usr/eclipse/plugins in $CLASSPATH, but I'm not sure if
that's needed/enough and doesn't work either.
Any other tip?
Thank you,
Eduardo.
strus escreveu:
> Be carefull to have java in your path.
> It appears in some of our systems with RedHat9 that java in /usr/bin
> does exit before installing a SDK and that this java is not JAVA
> So try the command
> java
> and verify that the good java is launched
> Eduardo Quaglia a écrit :
>> Hi.
>> Thanks,
>> Eduardo Quaglia.
>> .log file:
>> !SESSION
>> !STACK
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> !SESSION
>> !STACK
>> at
>> at
>> at
FUDForum. Page generated in 0.07591 seconds
