| Problem with Pie Chart and Labels [message #212325] |
Thu, 18 January 2007 06:24  |
Originally posted by: pietromarrone.gmail.com
I'm using
Birt Version: 2.1.0.N20060628-1351
Build id: 200606281537
Eclipse SDK
Version: 3.2.0
Build id: I20060602-1317
My Data for my Pie Chart are something like that:
Label Value
A 10
B 20
C 10000
So "A" and "B" slices are very small, labels of "A" and "B" comes
overlapped and it is impossible to read its value.
Labels shuold be positioned not right its own slice, but below or above,
in order to let the reader undersand the value.
Is it a bug or there is some feature that I can't found it (I searched a
lot).
I tried also to have 3D and 2D Pie Chart, Changing Pie Ratio and
dimentions,
nothing to do.
Please help me to findout a way to make labels readeable.
My deadline is very close.
Pietro Marrone
| Re: Problem with Pie Chart and Labels [message #212371 is a reply to message #212325] |
Thu, 18 January 2007 10:56  |
There is a bug for that:https://bugs.eclipse.org/bugs/show_bug.cgi?id=119068
I scheduled it for 2.2
In the meantime you can put your label inside the slice, or try to play with
the leader line length. In the last option, replace the label with a tooltip.
David
> I'm using
> Eclipse SDK
> Version: 3.2.0
> Label Value
> A 10
> B 20
> C 10000
> above, in order to let the reader undersand the value.
> a
> lot).
> dimentions,
> nothing to do.
> Please help me to findout a way to make labels readeable. My deadline
> is very close.
> Regards
> Pietro Marrone
FUDForum. Page generated in 0.03316 seconds
