Re: Questions about remote execution [message #20615 is a reply to message #20608] |
Tue, 15 April 2008 19:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Xuan![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=xuanchen%40ca.ibm.com) Messages: 4 Registered: July 2009 |
Junior Member |
Hi Denise,
User Action support is quite primitive right now, and we do plan to make
it better.
Right now, when you right click on a file or folder and choose any of a
submenu under Compile or User Action, a set of default compile commands
and user actions will be created for you. You could actually see those in
the Team View, by expanding your_profile_name -> Property sets.
As you probably know, you could define new Compile Command or User Action
by "Work With Compile Command" or "Work with User Actions" actions.
Right now, you could export those user actions as part of your profile,
but you could not export them separately yet. I checked with Dave
Dykstal, and he mentioned the API for exporting PropertySet is available
(User action and Compile command are implemented using PropertySet). So
what we could do is to add a an action on the your_profile_name ->
Property sets in Team view to call the proper API to export them. And add
import support to import them to RSE.
You could fire a bug to request for this feature, but it will probably be
in next our release.
Re: Questions about remote execution [message #573670 is a reply to message #20608] |
Tue, 15 April 2008 19:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Junior Member |
Hi Denise,
it better.
FUDForum. Page generated in 0.04456 seconds
