Why plugins don't start [message #211559] |
Tue, 22 May 2007 00:27 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: evaandoli.dodo.com.au
I posted a sort of related question on GMF then thought the fundermental
question is really for here.
So my question is How do you know why a plugin didn't start (say a dependant
jar is not there or incorrect version is missing or wrong Java JRE version
.. . . etc.).
I look at the Error log view in Eclipse but its empty, I look at the
console but empty.
Any help would be good,
Stu
Re: Why plugins don't start [message #211567 is a reply to message #211559] |
Tue, 22 May 2007 02:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Stu,
Typically the Error Log view (or the <workspace>/.metadata/.log) will
show diagnostics about what's gone wrong.
> . . . etc.).
> console but empty.
> Stu
Re: Why plugins don't start [message #211626 is a reply to message #211559] |
Tue, 22 May 2007 13:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> . . . etc.).
> console but empty.
This is not an easy question to answer nor a simple problem to solve.
See these bug reports for all the gory details:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=174515
https://bugs.eclipse.org/bugs/show_bug.cgi?id=155897
Hope this helps,
Eric
Re: Why plugins don't start [message #211640 is a reply to message #211559] |
Tue, 22 May 2007 16:53 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: wharley.bea.com
"Stu" <evaandoli@dodo.com.au> wrote in message
news:f2tdeg$9mf$1@build.eclipse.org...
> dependant jar is not there or incorrect version is missing or wrong Java
> JRE version . . . etc.).
If you add the -debug command line option you may get more information.
(There are also a host of more detailed debug options that can be turned on
using a .options file.)
FUDForum. Page generated in 0.07881 seconds
