Home » Eclipse Projects » GEF » How to listen to emf model
How to listen to emf model [message #211415] Fri, 10 March 2006 07:46 Go to next message
Originally posted by: shruthi.cn.in.bosch.com
Hello everybody,
I want to use EMF model for developing a GEF editor.
In the GEF sample "org.eclipse.gef.examples.shapes_3.1.0", the model and
the editparts uses java.beans.PropertyChangeListener and
java.beans.PropertyChangeSupport for notification on changes in the
property.
Now, in the generated EMF model and EMF.Edit framework classes, i saw that
EMF model also notifies using EMF's eNotify and notifyChanged.
notifyChanged, in turn fires event using fireNotifyChanged method. I also
saw that there is a function addListeners in
XXXXXItemProviderAdapterFactory.java in EMF.Edit framework inside the
providers package.
How can i make the EditParts listen to emf model?
Could anybody give a sample code for this. May be some links for EMF-GEF
working together would also help me. But sample code would be the best.
Thank you very much
Best Regards
Shruthi
Re: How to listen to emf model [message #211424 is a reply to message #211415] Fri, 10 March 2006 07:51 Go to previous messageGo to next message
Hello Shruthi,
Why not take a look at GMF? http://www.eclipse.org/gmf
- Rich
> Hello everybody,
> and the editparts uses java.beans.PropertyChangeListener and
> property.
> that EMF model also notifies using EMF's eNotify and notifyChanged.
> also saw that there is a function addListeners in
> providers package.
> EMF-GEF working together would also help me. But sample code would be
> the best.
> Thank you very much
> Best Regards
> Shruthi
Re: How to listen to emf model [message #211696 is a reply to message #211415] Wed, 15 March 2006 06:51 Go to previous message
Hi Shruthi,
probably a question for the emf group but I was glad that somebody
answered when I posted to the uml2 group :), so here are some hints for
you (but beware I am also a newbie trying to find things out):
Your listener must implement org.eclipse.emf.common.notify.Adapter
In Adapter, there is "public void notifyChanged(Notification n)". This
gets called when something changes. There you can switch on the feature id:
switch (n.getFeatureID(Classifier.class))
case UML2Package.PROPERTY__NAME:
refreshVisuals();
break;
... etc ...
(This example is specific to the uml2 stuff.)
Notification has methods to find out what has changed and the old and
new values.
You register your listener like this:
eobject.eAdapters().add(listener);
To remove it, call
eobject.eAdapters().remove(listener);
Hope that gets you going, Thomas.
Shruthi schrieb:
> Hello everybody,
> property.
> providers package.
> Thank you very much
> Best Regards
> Shruthi
Previous Topic:How to add a splitter to GEF editor?
Next Topic:Drag drop - creating multiple elements at once
Current Time: Sat Oct 18 04:32:14 EDT 2025
Powered by FUDForum. Page generated in 0.04659 seconds
