Home » Eclipse Projects » GEF » Mixing 2d drawing and UI widgets
| Mixing 2d drawing and UI widgets [message #20447] |
Wed, 25 September 2002 09:34  |
Originally posted by: ed.burnette.no.spam.sas.com
Would GEF be appropriate for creating an editor or view that mixes standard
UI objects with freehand drawings? Something like this:
http://msdn.microsoft.com/vstudio/art/img_adoplusfig4.gif
In this case you don't want to try to emulate the standard widgets (lists,
grids, etc.), you just want to use the real native widgets and windows but
add some annotation around them (for example showing the relationship
between tables and nodes, that sort of thing).
Advice on how to use GEF for something like this or on a better way to go
would be appreciated. I'm just learning about Eclipse and building plugins
so pardon me if this is a misguided question. I searched the archives and
faq first but didn't see a relevant answer. TIA.
-- Ed
(remove no.spam. from email)
| Re: Mixing 2d drawing and UI widgets [message #20638 is a reply to message #20447] |
Wed, 25 September 2002 11:03   |
Originally posted by: hudsonr.us.eye-bee-em.com
You could do something that looks like that by writing your own "table"
Figure. This would be a really cool thing to add to draw2d. Others have
done this already. Some people have placed SWT Tables directly on the
Graphical Viewer, but this has limitations, because you can't paint on top
of that table very easily, and you'd have to customize the viewer a lot.
"Ed Burnette" <ed.burnette@no.spam.sas.com> wrote in message
news:amscsv$cnh$1@rogue.oti.com...
standard
Actually, there are reasons to emulate tables, but maybe none of them
applies to what you are trying to do. Reasons might include changing the
appearance of a TableItem, better "cell" support, and support for really
large data sets.
> -- Ed
| Re: Mixing 2d drawing and UI widgets [message #21216 is a reply to message #20638] |
Thu, 26 September 2002 17:08   |
Originally posted by: mec.enteract.com
We're grappling with a similar problem here - we want to basically throw an
entire custom panel of widgets (buttons, list boxes, tables, whatever)
inside of a figure in a GEF editor as a connectible figure. Here's what
we've been futzing around with and can't get to work:
1) Derive our object (InteractionFigure) from Figure
2) Add a myComposite member that is a new SWT Composite
3) Then, we overload the paint function in InteractionFigure to resize
myComposite to be in the exact place and size as the InteractionFigure.
Then we tell myComposite to redraw.
Obviously this isn't working, so I'm worried that as a newbie I just don't
understand something fundamental. Will this ever work? Can I have a
floating Composite that sits on top of my figure that gets repainted at the
right times and contains a set of SWT widgets?
Michael
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:amsi4q$gib$1@rogue.oti.com...
> standard
(lists,
but
> large data sets.
go
plugins
and
> > -- Ed
| Re: Mixing 2d drawing and UI widgets [message #21483 is a reply to message #21216] |
Thu, 26 September 2002 21:24   |
"Michael Cloran" <mec@enteract.com> wrote in message
news:amvrrm$duj$1@rogue.oti.com...
an
You should use an AncestorListener. This is what the selection handles in
GEF use to follow a figure. When the ancestor listener is notified, you
need to take the InteractionFigure's Bounds, and then call
interactionFigure.translateToAbsolute(copiedBoundsRectangle) , then place the
native composite in that location.
the
You never have to ask native controls to repaint. This is automatic. It
should work, but with the limitations mentioned before.
> Michael
have
top
> > standard
> (lists,
> but
the
> > large data sets.
> go
> plugins
> and
> > > -- Ed
| Re: Mixing 2d drawing and UI widgets [message #25903 is a reply to message #21483] |
Wed, 09 October 2002 06:45   |
The below was great advice. Thanks Randy.
The AncestorListener works great. Everytime I move a figure the moved
function gets called and all I do is this:
public void ancestorMoved(IFigure ancestor) {
Rectangle rect = getFigure().getBounds();
getFigure().translateToAbsolute(rect);
wrapperPanel.setBounds(rect.x+1, rect.y+1, rect.width-2, rect.height-2);
I thought I was done a week ago...then tonight (this morning since it is now
6am?) I finally used the scrollbars and *shock* the figure borders move when
the scrollbars move but my panels that were floating on top of them stay
still. I can't believe I didn't notice this until now.
Anyway - I'm probably just being lazy - but is there the equivalent of
'AncestorListener' for when the main panel is scrolled? I've looked through
ScrollingGraphicalViewer and FreeformGraphicalRootEditPart and can't find
any obvious place to pick up this event.
Sorry if this is an obvious question - been at work for 21 hours now...
Michael
> an
the
don't
> the
> > Thanks,
> > Michael
"table"
> have
> top
lot.
> > > standard
> > (lists,
windows
> > but
relationship
> the
really
> > > large data sets.
to
> > go
> > plugins
archives
> > and
> > > > -- Ed
| Re: Mixing 2d drawing and UI widgets [message #26307 is a reply to message #25903] |
Wed, 09 October 2002 10:42  |
news:ao0vvv$hri$1@rogue.oti.com...
now
when
through
> Michael
This has been fixed (yea!) so that scrolling the ScrollingGraphicalViewer
(which uses FigureCanvas), will also scroll any SWT Controls that are
*children* of the FigureCanvas. Notification is *purposely* disabled for
that scrolling to prevent the entire diagram from laying out when nothing is
moving. (Actually, just the connection and selection handles would think
that they need to layout, but its still wasteful).
This fix is in CVS for now. Eclipse.org has almost ironed out build issues
with us so that we can provide nightly builds via an automated build page.
If you want to try the fix locally, hack FigureCanvas.scrollToY(int) so that
the call to scroll(int, int, int, .... boolean); has *true* at the end (the
last parameter).
Current Time: Mon Nov 03 03:29:48 EST 2025
Powered by FUDForum. Page generated in 0.33366 seconds
