Home » Eclipse Projects » Plugin Development Environment (PDE) » Help plugin functions in 3.3, but not in 3.4
Re: Help plugin functions in 3.3, but not in 3.4 [message #21051 is a reply to message #20444] |
Wed, 10 September 2008 20:43 |
Originally posted by: nospam_kowalskilee.gmail.com
Hi James,
The best newsgroup would be eclipse.platform.ua. I'm adding that
newsgroup to this thread.
Can you describe more about how you are adding the help plug-in to
Eclipse 3.3 and 3.4?
Yes, things have changed between the two versions. In Eclipse 3.4, the
method for providing plug-ins has changed. You can't simply add a new
plug-in to the plugins directory any more. There is a "dropins"
directory into which you can drop plug-ins. Sometimes you have to use
the -clean parameter on startup to ensure that Eclipse recognizes to
check the dropins directory.
Did you create your help plug-in with PDE or some other tool?
Lee Anne
James Hurrell wrote:
> I'm hoping this is the right group, please tell me if not!
> I need to intergrate a simple Help plugin into both Eclipse 3.3 and 3.4.
> My test plugin functions correctly in version 3.3, but does not show up
> in version 3.4.
> Has something changed between the two versions?
> Thanks.
> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #21197 is a reply to message #21051] |
Fri, 12 September 2008 04:22 |
Ketan Padegaonkar Messages: 873 Registered: July 2009 |
I'm facing a similar issue, I'm packaging the help in a 3.4 based
product, and my help plugin does not seem to contribute to the help at all.
Did you get to resolve this issue ?
-- Ketan
Lee Anne wrote:
> Hi James,
> Best regards,
> Lee Anne
>> 3.4. My test plugin functions correctly in version 3.3, but does not
>> show up in version 3.4.
>> Thanks.
>> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #21276 is a reply to message #21197] |
Fri, 12 September 2008 15:12 |
Hi Ketan
How did you create your help plug-in? Using PDE or another tool?
Does it have a MANIFEST.MF file?
How are you adding in the help plug-in? Are you putting it into the
plugins directory or the dropins directory or exporting it using the PDE?
In general, I have seen comments from people stating that they have
dropped plug-ins into dropins and sometimes they are picked up, and
sometimes they aren't and then 'magically' they are. For example, see
this eclipse.platform thread from July:
http://dev.eclipse.org/newslists/news.eclipse.platform/msg76 369.html
Ed Merks wrote:
"Yes, I ran into a weird problem where I changed the version of a plugin
from 2.4.0 to 2.4.1 and it caused the plugins to fail to resolve for
mysterious reasons and my efforts to clear the configuration made a
mess; eclipse would start, but Java projects weren't recognized as Java
projects anymore. I'm not sure what the proper way to force a clean
revisiting of all the dependencies. I've heard someone say -clean does
nothing for p2, but that might just be an ugly rumor. "
You could try using the -debug flag to get more details about what
Eclipse is doing as it is starting.
I haven't done any more iterative tests since my last posting. I did get
a help plug-in to appear when I removed the version portion of the
plug-in's directory (so that it was like com.blah.doc and not
com.blah.doc_1.0.9). But I could not get a repeatable experiment yet to
submit a bug or pinpoint the behavior.
Hope this helps,
Lee Anne
> -- Ketan
Re: Help plugin functions in 3.3, but not in 3.4 [message #579716 is a reply to message #20444] |
Hi James,
Lee Anne
> in version 3.4.
> Thanks.
> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #579913 is a reply to message #21051] |
-- Ketan
Lee Anne wrote:
> Hi James,
> Best regards,
> Lee Anne
>> Thanks.
>> James Hurrell
Re: Help plugin functions in 3.3, but not in 3.4 [message #580009 is a reply to message #21197] |
Hi Ketan
Hope this helps,
Lee Anne
> -- Ketan
Current Time: Thu Dec 26 23:31:08 GMT 2024
Powered by FUDForum. Page generated in 0.04188 seconds
