Re: how to add widget to a composite after the composite is displayed ? [message #211196 is a reply to message #211108] |
Wed, 08 March 2006 21:46 |
Originally posted by: kwpeck.mersoft.com
Seems like more of a SWT question to me but I will see if I can help.
In general you need to build your full layout then hide the widgets you
don't want to see. When they press the button you make widgets visible.
I don't believe, and I could be wrong, that you can add a widget to a
composite later. They all must be there from the start and you can show
and hide them as needed from there.
heima2008 wrote:
> if a composite is showed in runtime ,and I click a button to create a Text to be put in this composite .
> but the added Text couldn't be show even I redraw the composite.
> Could someone tell the cause.
FUDForum. Page generated in 0.13174 seconds
