classloader being flaky with JDT classes [message #210802] |
Mon, 25 July 2005 17:48 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: nothanks.spammedalot.net
Hi there -
Last week I posted a couple times about a ClassDefNotFoundError I keep
getting while calling JDT core classes in a plugin that *does not* extend
JDT. Someone asked me to post and include the stack trace, and when I ran
it again to get the trace, the error magically went away. However, it
still happens regularly with our QA machine, and I really don't know why.
My plugin extends IStartup only. I make use of JavaCore get information
from Java projects loaded in the user's workspace, and JavaUI to perform
other tasks. So, my plugin.xml has the following lines:
<requires>
<import plugin="org.eclipse.jdt"/>
<import plugin="org.eclipse.jdt.core"/>
<import plugin="org.eclipse.jdt.ui"/>
</requires>
The first time my plugin calls any of these classes (I call
JavaCore.getJavaCore in startup) Eclipse throws a ClassDefNotFoundError on
JavaCore. Since the call occurs in startup, my plugin fails to load at
all.
Ideally, I don't want to take the JDT loadup hit when Eclipse is starting
up, so I've tried delaying the call to getJavaCore until it is actually
needed, but Eclipse throws there as well.
I have two Eclipse installs on my test computer - one where the plugin
works (and JavaCore resolves without an error) and one where the
ClassDefNotFoundError is thrown. I'm working on figuring out the
differences between the two installs. In the meantime, I'm curious if
there's something I need to do in my plugin code besides requiring those
jdt imports? I don't know the Eclipse API all that well - I was merely
assigned a bug to fix.
Thanks for any help,
- Chris
Here's the .log entry:
!ENTRY com.mycompany.myproduct.plugins.eclipse 4 0 Jul 25, 2005
13:30:35.383
!MESSAGE startup class must implement org.eclipse.ui.IStartup
!SESSION Jul 25, 2005 13:32:05.695
eclipse.buildId=M200503110845
java.version=1.4.2_04
!ENTRY org.eclipse.core.runtime 4 2 Jul 25, 2005 13:32:05.758
!MESSAGE Problems encountered starting up plug-in:
"org.osgi.framework.BundleException: Exception in
com.mycompany.myproduct.plugins.eclipse.EclipseLauncherPlugi n.start() of
bundle com.mycompany.myproduct.plugins.eclipse.".
!STACK 0
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:975)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:937)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:421)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:293)
org.eclipse.core.internal.plugins.PluginDescriptor.doPluginA ctivation(PluginDescriptor.java:349)
org.eclipse.core.internal.plugins.PluginDescriptor.getPlugin (PluginDescriptor.java:328)
org.eclipse.ui.internal.EarlyStartupRunnable.getPluginForCom patibility(EarlyStartupRunnable.java:140)
org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:68)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.ui.internal.Workbench$15.run(Workbench.java:1283 )
at java.lang.Thread.run(Thread.java:534)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jdt/core/JavaCore
com.mycompany.myproduct.plugins.eclipse.EclipseLauncherPlugi n.start(EclipseLauncherPlugin.java:51)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$1 .run(BundleContextImpl.java:958)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:954)
... 15 more
Root exception:
!ENTRY org.eclipse.ui 4 4 Jul 25, 2005 13:32:05.773
!MESSAGE Unhandled Exception
FUDForum. Page generated in 0.03018 seconds
