Home » Eclipse Projects » GEF » How to create filled and not filled triangle at the end points of connection
How to create filled and not filled triangle at the end points of connection [message #210763] Mon, 06 March 2006 00:01 Go to next message
Originally posted by: rupesh_wakde.yahoo.com
Can anybody tell me how to create not filled triangle(used for
association)and filled at the end points of the connection.
Re: How to create filled and not filled triangle at the end points of connection [message #210843 is a reply to message #210763] Mon, 06 March 2006 10:11 Go to previous message
You would create a subclass of PolylineDecoration and install it on your
PolylineConnection. I believe you would use the Shape#setFill method to
indicate it needs to be filled and then override the fillShape and call
g.drawPolygon(points).
@see
org.eclipse.gef.examples.ediagram.edit.parts.ReferenceLinkEd itPart#createPol
ylineDecoration
-Steve
"rupesh" <rupesh_wakde@yahoo.com> wrote in message
news:b710e47ada67a1dc4a2cc111cc65962f$1@www.eclipse.org...
Previous Topic:Active Editor ?
Next Topic:one problem at PolylineConnection.class [GEF]
Current Time: Fri Mar 14 06:19:00 EDT 2025
Powered by FUDForum. Page generated in 0.01650 seconds
