Home » Newcomers » Newcomers » How do I get source code?
How do I get source code? [message #210350] Fri, 11 May 2007 11:53 Go to next message
Originally posted by: john.blutarsky.hotmail.com
How can I get a project with all the source code inlcuded.
In particular I need to be able edit some of the plug-ins of a project and
can't with the version I have.
I can see the code but cannpt edit it as the java is not in source form.
The project (GMF) is a particulr mile stone.
Should I get this through CVS or os there another way around it?
Thank you for your help,
John
Re: How do I get source code? [message #210358 is a reply to message #210350] Fri, 11 May 2007 12:11 Go to previous message
John,
Assuming you have the source plugins for it installed, you can use
File-Import->Plug-in Development->Plug-ins and Fragments. Be sure to do
Import As->Projects with source folders. Or you could get them from
CVS, e.g., /cvsroot/modeling/org.eclipse.gmf/plugins/org.eclipse.gmf.
John Bluto wrote:
> Hello,
> and can't with the version I have.
> John
Previous Topic:OSGI Bundle
Next Topic:Adding a help page into a help contents which already exists
Current Time: Mon Jan 13 19:12:26 GMT 2025
Powered by FUDForum. Page generated in 0.07078 seconds
