how can I check out multiple projects in one go? [message #209891] |
Fri, 15 July 2005 14:22 |
Originally posted by: daniel.dickman.lehman.com
I am trying to get CVS set up so I can check out multiple java projects at
one time.
When I did a search of the eclipse docs for "cvs module" I found the
following phrase:
"...checkout the module into one or more projects in the local workspace,
depending on how the module is defined in the repository."
Unfortunately I couldn't figure out how to define a module in CVS so that
I can check it out into multiple Java projects. Does anyone know how to do
this? Any help would really be appreciated.
Daniel
Re: how can I check out multiple projects in one go? [message #209931 is a reply to message #209891] |
Sat, 16 July 2005 01:08 |
Originally posted by: plankton.softwitch.net
in CVS Repository Exploring perspective. Select project modules which
you want, and right-click, and select checkout. that's all.
Daniel Dickman wrote:
> Hello,
> at one time.
> following phrase:
> workspace, depending on how the module is defined in the repository."
> that I can check it out into multiple Java projects. Does anyone know
> how to do this? Any help would really be appreciated.
> Daniel
FUDForum. Page generated in 0.04179 seconds
