Home » Eclipse Projects » Eclipse Platform » Running Eclipse without the Binary
Running Eclipse without the Binary [message #209800] Thu, 11 March 2004 13:19 Go to next message
Originally posted by: tom.soraoka.com
Is there a way to run eclipse without the binary part?
...and without having to build it from source code?
I'm new to Eclipse, but veteran in Java, and work in
a military installation that has an unsupported OS -
Solaris 2.6. Java 1.4.1 runs just fine, but I can't
seem to find the binary portion of Eclipse that starts
the IDE. It would be better if I can just set the
classpath and just run the Java vm.
Re: Running Eclipse without the Binary [message #210026 is a reply to message #209800] Thu, 11 March 2004 17:46 Go to previous messageGo to next message
Originally posted by: newsserver_mails.bodden.de
This should be doable. Have a look at the jar files in the plugin
org.eclipse.core.boot.
Eric
Tom Soraoka maundered in <c2qaj2$ns5$1@eclipse.org>
Eric Bodden
ICQ UIN: 12656220
Website: http://www.bodden.de
PGP key available
Re: Running Eclipse without the Binary [message #210613 is a reply to message #210026] Fri, 12 March 2004 11:35 Go to previous messageGo to next message
All the plugin jar files have class files, no java files, so I wasn't
sure which one had "main" in it. But I did find a class called "Main"
and it runs, but never renders any GUI.
> Eric
Re: Running Eclipse without the Binary [message #210679 is a reply to message #210613] Fri, 12 March 2004 13:41 Go to previous message
Originally posted by: b_kack.hotmail.com
Try
java -cp $ECLIPSE_HOME/startup.jar org.eclipse.core.launcher.Main
But I believe you'll have to have the libraries for SWT ported for Solaris
2.6. You'll find the source for these in
org.eclipse.platform.solaris.motif.source_2.1.0
> > Eric
Previous Topic:throwing exceptions when trying to start an object that extends ViewPart
Next Topic:how to add buttons to bottom of Wizard
Current Time: Sun Oct 19 19:12:49 EDT 2025
Powered by FUDForum. Page generated in 0.03863 seconds
