Error "The requested resource is not available" when trying WPT Tutorial [message #209530] |
Tue, 04 March 2008 19:54 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: markus.heid.email.de
I've trying the buttom up webservice example as described here:
http://www.eclipse.org/webtools/community/tutorials/BottomUp Axis2WebService/bu_tutorial.html
But when I'm starting the tutorial with Run as -> Run on Server
I'm getting a 404 error page in eclipse.
The error page tells me: The requested resource is not available.
The console messages while starting the tomcat tells me that:
Mar 4, 2008 7:48:39 PM org.apache.tomcat.util.digester.SetPropertiesRule
begin
WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting
property 'source' to 'org.eclipse.jst.jee.server:HGWS' did not find a
matching property.
Mar 4, 2008 7:48:39 PM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal
performance in production environments was not found on the
java.library.path:
C:\Programme\Java\jre1.6.0_04\bin;.;C:\WINDOWS\Sun\Java\bin; C:\WINDOWS\system32;C:\WINDOWS;C:\Programme\Java\jre1.6.0_04 \bin\client;C:\Programme\Java\jre1.6.0_04\bin;C:\WINDOWS\sys tem32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Programme\ATI
Technologies\ATI.ACE\;C:\Programme\QuickTime\QTSystem\;d:\an droid\sdk\tools;C:\Programme\Microsoft
SQL
Server\90\Tools\binn\;C:\Programme\Subversion\bin;C:\Program \Files\jboss-4.0.5.GA\bin;d:\ant\bin;d:\axis2-1.3\bin;;C:\Su n\SDK\bin;d:\android\sdk
Mar 4, 2008 7:48:40 PM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-8080
Mar 4, 2008 7:48:40 PM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1796 ms
Mar 4, 2008 7:48:40 PM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Mar 4, 2008 7:48:40 PM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.16
[INFO] Deploying module: addressing-1.3
[INFO] Deploying module: metadataExchange-1.3
[INFO] Deploying module: ping-1.3
[INFO] Deploying module: script-1.3
[INFO] Deploying module: soapmonitor-1.3
[INFO] script module activated
[INFO] Deploying Web service: HuntGameWS2
[INFO] Deploying Web service: version.aar
Mar 4, 2008 7:48:46 PM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Mar 4, 2008 7:48:46 PM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Mar 4, 2008 7:48:46 PM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/93 config=null
Mar 4, 2008 7:48:46 PM org.apache.catalina.startup.Catalina start
INFO: Server startup in 6104 ms
My eclipse version is Version: 3.3.0
Build id: I20070625-1500
My WPT version is: 2.0.0
My Tomcat is 6.0.16
I've searching the web for a while for a solutions but found nothing yet.
Thank you for helping
Markus
Re: Error "The requested resource is not available" when trying WPT Tutorial [message #209638 is a reply to message #209530] |
Wed, 05 March 2008 14:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Larry Isaacs![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=larryisaacs%40mindspring.com) Messages: 1354 Registered: July 2009 |
Markus Heid wrote:
> begin
> matching property.
> java.library.path:
> SQL
> My Tomcat is 6.0.16
> Markus
When you create the Dynamic Web Project, make sure you change the
Dynamic Web Module version on the Project Facets page to "2.4", like it
is shown in the tutorial. It is probably defaulting to "2.5" because of
Tomcat 6.0.16. Using "2.4" works for me, where "2.5" yields the same
result that you are seeing. I'm not sure of the source of this
behavioral difference.
Larry
thx [message #209683 is a reply to message #209638] |
Wed, 05 March 2008 20:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Larry Isaacs schrieb:
> Markus Heid wrote:
>> org.apache.tomcat.util.digester.SetPropertiesRule begin
>> Setting property 'source' to 'org.eclipse.jst.jee.server:HGWS' did not
>> find a matching property.
>> java.library.path:
>> SQL
>> My Tomcat is 6.0.16
>> Markus
> Cheers,
> Larry
Thank you,
is was the solutions i've been looking for so long.
FUDForum. Page generated in 0.03432 seconds
