Home » Eclipse Projects » GEF » Lable outside the figure
Lable outside the figure [message #209504] Wed, 15 February 2006 11:52 Go to next message
when we create a Polylineconnection we are able to add labels "outside"
of the label. If we use the implementation of GMF we are able to move
the label.
Now we want to do the same thing for a "normal" figure. Is it possible
to create a figure which has a label outside? The label should be
moveable and the label's position is relative to the figure
HelloWorld
Now we move the label:
* * HelloWorld
And now the figure:
* * HelloWorld
Stefan
Re: Lable outside the figure [message #209527 is a reply to message #209504] Wed, 15 February 2006 14:25 Go to previous messageGo to next message
I have had the same problem. I have solved them that
the label and the 'normal figure' have the same parent.
/---Label
parentContainer --/
\---Figure
.....AND the Figure has a Reference to the label.
If you move the Figure you must move the Label with the diff. too.
If you move the Label do nothing with the parent.
Now the Label has always the same relative position to the Figure.
greetings
Andreas
Re: Lable outside the figure [message #209561 is a reply to message #209527] Thu, 16 February 2006 03:48 Go to previous messageGo to next message
thanks for the answer. I have considered a similar solution but as far
as I understand the parent container will do clipping to its children so
I have to resize the aprent container if I move the Label around.
This will generate huge invisible parent container which have to be
synchronized when dragging labels around.
Greetings,
Stefan
FreeGroup wrote:
> /---Label
> parentContainer --/
> \---Figure
> greetings
> Andreas
Re: Lable outside the figure [message #209664 is a reply to message #209561] Fri, 17 February 2006 12:53 Go to previous message
the parentContainer is my common container for ALL elements.
In my case I have only one parentContainer, the rootEditPart
greetings
Andreas
Previous Topic:DirectedGraph connection routing
Next Topic:Property Window
Current Time: Wed Oct 22 04:09:54 EDT 2025
Powered by FUDForum. Page generated in 0.04778 seconds
