JULI Logging on Apache Tomcat 5.5 from WTP [message #209128] |
Mon, 25 February 2008 20:59 |
I would like to activate the logging for Tomcat 5.5. I did find this FAQ
entry:
http://wiki.eclipse.org/WTP_Tomcat_FAQ#How_do_I_enable_the_J ULI_logging_in_a_Tomcat_5.5_Server_instance.3F
Unfortunately the following sentense does not reveal its secrets to me:
------------Quote----------------
a.. Open the server editor for the Tomcat server and note the folder
specified by the Configuration path field.
In the server view I can select the properties and here I don't find a
"Configuration path field". Also in the preferences I don't find a field
I also tried to find this info in the editor for the server.xml file which
can be found under "Servers" in your Java EE perspective. But I did not find
"Configuration path" or any other similar entry in this file.
A text search within the project for "configuration path" and "path" also
did not return any useful results.
Any advice?
Best regards, Lars
Re: JULI Logging on Apache Tomcat 5.5 from WTP [message #209867 is a reply to message #209136] |
Thu, 06 March 2008 21:02 |
Hi Larry,
thank you for your advice. Best regards, Lars
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:fq15lq$h92$1@build.eclipse.org...
> Lars Vogel wrote:
>> entry:
> It appears that when this page was moved to the wiki, all the links that
> existed within the page were lost or you would have had your answer. See
> the first question in the Information section of the Tomcat FAQ for how to
> open the editor. I'll see if I can update the page to fix this and add
> 2.0.x info.
> Cheers,
> Larry
>> which can be found under "Servers" in your Java EE perspective. But I did
>> not find "Configuration path" or any other similar entry in this file.
>> Any advice?
>> Best regards, Lars
FUDForum. Page generated in 0.02947 seconds
